Question about Garden
How do i change the oil in a 1.5hp 3gl craftsman air compressor
    Master:
  • 343 Answers
If your compressor is not an oiless unit there will be a plug or dipstick at a low point of the cylindrer head assembly. Most people pull the plug and lean on its side over a suitable container to drain. fill with craftsman compressor oil or equivalent, do not over fill.
Posted on Oct 04, 2010
Manual for craftsman 33 gal 6 hp 919-165500
Craftsman Portable Oil Free Direct Drive Air Compressor Parts 919 165500
Illustrations of Sears Craftsman at the link above for:
Portable Oil-Free Direct-Drive Air Compressor
Jan 30, 2018 | Craftsman Air Tools & Compressors
Craftsman 5hp electric model 19551, type oil used and amount?
if you go to you tube Craftsman 3 gallon air pump oil change ,it tells you the brand of oil and shows the amount needed . hope this helps .
Dec 22, 2015 | Craftsman Air Tools & Compressors
My new 80 gallon Craftsman Professional air compressor's oil turned dark right away. I changed the oil and it happened again. Is there a problem? Thanks, Trevor
Problem sounds like the type of oil being used. The oil should be a gold color. It will get dark over time but not like oil in a car. Check your owners manual to be sure that the right oil is being used.
Compressors use a 30 weight non detergent oil. If you don't have a manual Go to any Sears Home and garden Department and they will be able to help you.
Feb 22, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
What type of oil does me Craftsmen 1.5 air compressor use
It uses a special oil, not motor oil, it is called Craftsman 2 Stage Compressor Oil, here is a link to the oil.
http://www.sears.com/shc/s/p_10153_12605_00916427000P?i_cntr=1295304743644
Jan 17, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I just bought a used Craftsman air compressor at a garage sale...100PSI, twin cylinder, 1HP motor. Model # 106.154440. Runs fine, but wondered how to check the oil level in the compressor case and if it...
I have a Sears 106.154581 most likely like yours. You will find a small plug (fill hole) and slightly larger plug on side of pump close to bottom (drain hole). Fill compressor with compressor oil to top thread of fill hole. Oil should look rather clear with very little odor. Compressor oil is available at Lowes for about $3. Good luck
Aug 16, 2010 | Craftsman Air Tools & Compressors
Problem starting fom cold
have you put too thick an oil in it???? or none at all??as if it starts and runs all day there,s not much wrong with it? i'm thinking its very thick oil, or lack of any oil or starter capacitor???
its very tight to turn over when starting up first thing,
are you running it on a long extension lead???
is it a 1,5hp??? it needs a 13amp fuse???,
the sip has a capacitor start motor fitted, it could be the cap going down on you?? dont play with the capacitor, they can and will kill you!!! machine mart may fix it for you?
Oct 20, 2009 | Air Tools & Compressors
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
