Question about Canon PIXMA MX700 All-In-One InkJet Printer
I have a Canon PIXMA MX860 and have error 5100. Is there a fix for that? It clears itself when I turn it off/on, but I am doing that 10 times a day.
SOURCE: Service error 5100 on my canon Pixma mp110
Had the same problem, i just replaced the black ink cartridge which was finishing at that time and resetted the counters. No problems after that. Not sure whether this will help though.
Posted on Aug 31, 2008
just replaced the ink cartridges and reset the counters, evrth ok now :-)
Posted on Nov 09, 2008
  • 412 Answers
SOURCE: Canon Pixma MP830 error 5100
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
komguy
  • 2306 Answers
SOURCE: I have a Canon PIXMA MX860 and have error 6a80. i
6A80 is a purge unit error, the purge unit is the cleaning assembly on the right where the printhead parks when shut down. If you can move the carriage out of the corner, use a flashlight and see if there are paper scraps or the like keeping the purge assembly from moving freely.
Posted on Oct 13, 2009
pineworks
  • 4041 Answers
SOURCE: Canon pixma mp170 error code 5100
Hi You can Try
Seen lots of ths errors
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Jan 28, 2010
How do I reset or fix an Error B200 Code on a Canon PIXMA MX860 Printer?
Dear
Please try the following to see if we can resolve your issue:
1. Open the cover of the printer.
2. Remove all ink tanks from the printer.
3. Lift up the gray locking lever on the side of the ink tank holder.
4. Gently remove the print head from the carriage unit.
5. Place the print head back in and lock the lever down.
6. Place all of the ink tanks back in the printer.
7. Close the cover and turn the printer off.
8. Unplug the power from the printer. Leave the power unplugged for about 5-10 minutes.
9. Plug the power back in and turn the printer on.
Thanks
Jan 15, 2015 | Canon PIXMA MX860 All-In-One InkJet...
Canon pixma mx432 printer error 5100
I have a Canon mx432 that was new, but gave me a 5100 message that I couldn't clear. I cleaned the transparent belt that guides the print cartridges, and now it works great. I spent hours on it until I cleaned that strip - - nothing else worked
Sep 12, 2012 | Canon Pixma MX420 All-In-One Printer
Canon mx860 - had an error code C000 and now a day later 306A
Error code C000. Cancel printing, and turn off the machine. Then clear the paper jam or foreign object that is preventing the Print Head Holder from moving.
For more information about the error code C000, can be read here Canon Support and Downloads
You read, the bottom of the page
Sep 23, 2011 | Canon PIXMA MX860 All-In-One InkJet...
Problem 5100 in my canon mx860. Help
What do you do with error c1000 on a canon MX860?
Feb 28, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Hello, I have a Canon Pixma MX860 all in one copier printer that just began to display error #5100. All the ink cartridges are full. How do I reset the printer so that this error will not be displayed...
Turn off printer.
Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
Return the cartridges and turn on the printer.
Error 5100 means that the cartridge can not be detected by the printer.
Hope it helps1
Dec 18, 2010 | Microscan MS-860 Fixed/Industrial Barcode...
Mar 16, 2008 | Canon PIXMA MP780 All-In-One InkJet...
PIXMA iP8500
Error 5100 on Canon Pixma iP8500. flashes orange 2 times. Sounds like the paper isn't being picked up. But I don't know how to fix it.
Jan 03, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Canon PIXMA MX700 All-In-One InkJet Printer Logo
414 people viewed this question
old marine
old marine
