Question about Garden
Is there a bolt that hold the clutch from moving on a simplicity riding tractor
  • queenrachel0
    queenrachel0 Sep 18, 2012
    So is it simplicity.com
    Brigadier General:
  • 3,911 Answers
There are free manuals and illustrated parts breakdown pdf documents available for download on the simplicity website. perhaps if you googled "simplicity, lawn tractor, and your model number" you could find the answer yourself instead of asking someone else to do it for you?
teach a man to fish
Posted on Oct 05, 2010
How do you change the arbor bearings on an simplicity regent with a 50 inch cut?
You must take the blades and belt off and the well as pulley, the arbor is replaced as a unit and it unbolts with several bolts.
Jul 28, 2014 | Simplicity Regent Riding Mower 23 HP...
How to change out an electric clutch on a cub cadet zero turn RZT50?
Removal is simple if you have access to an impact wrench so you can the center retaining bolt.
When re-installing anti-seize compound needs to used on the crankshaft so the new clutch assembly doesn't seize on the shaft. To tighten the center bolt you must hold the flywheel in place by blocking it. This center bolt must be torqued to 45-55 ft fts. Also the new pto clutch needs burnishing in. Most new clutches come with instruction on this procedure.
Jul 23, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
Why does my Simplicity Citation keep blowing the PTO Clutch 20A Fuse?
If a fuse keeps blowing it means there is an intermittent short in the wiring or a faulty PTO clutch. Either way you need to fix it, not just keep replacing the fuse. Take it to an authorised repairer and tell them what is happening.
May 20, 2014 | Simplicity 5900523 - Citation 52" 22HP...
Mower deck slows and stops when I turn my Simplicity riding mower to the left,
HI,
The simplicity has a a two point mounting system for the deck. It attaches to the front axle which has two runners that go to the front axle's rear support bracket.
Closely check the runners near where the pins that hold the mower deck. They are known for cracking and breakage. Secondly, closely check the decks metal center support bracket, it bolts to the center of the deck and supports the idler pulleys as well as the deck alignment and mounting. Those, too, are known to crack near the front just behind the front pulley.
Aug 25, 2012 | Garden
YTS 3000 clutch return spring noise, sounds like it is rubbing on something when you release the clutch but I can't even find the spring
The spring will be attached to the tensioner pully right on top, there is a threaded bolt with nut holding the spring on, I just had to order the clutch cable because the spring broke, from rubbing on metal when engaging and disengaging the clutch lever.
Jul 30, 2010 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Garden tools riding mowers simplicity
They do not make that pto clutch anymore but you can buy a electric pto clutch for around $200.00 -$300.00 You will need to check the shaft size it should be 1" or 1 1/8" I could give you more info but you need to find it your self.
Paulo
good luck
Oct 27, 2009 | Garden
How do I remove electric clutch pulley on Craftsman 917.257720 lawn tractor?
if i'm not mistaken there should be a bolt in the center of the clutch that screws to the crankshaft remove top cover and have someone hold a wrench or socket on the top nut while another unscrews the bolt running through the clutch (righty tighty lefty loosey) may need to unbolt the steel rod that keeps the clutch housing from spinning. also dont forget to unplug the wires hope this helps
Jul 19, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Hydrostatic ridin mower 917270821 will not move. motor runs .
check key in clutch and fluid one bolt to take off clutch .tractor is a problem for losing bolt when putting bolt in put some locktight on threds .you might have to use a filergage to reset clutch there are three spots on clutch turn it to each spot.
Mar 10, 2009 | Craftsman Garden
Garden Logo
191 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
