Question about Canon BubbleJet i560 InkJet Printer
Printer runs but does not print text - Canon BubbleJet i560 InkJet Printer
  • Canon Master
  • 6,487 Answers
Base from the description of your problem the issue here is a printer software/driver related.
So what we can do here is to uninstall and reinstall your printer software from your computer, after you uninstall the printer software from add/remove program on control panel Restart the computer and then reinstall the printer software for it.
Posted on Oct 04, 2010
How do i repair my canon MX456 from printing blurry/double images and text
Your printer may be printing fuzzy, blurry, or other faint text because of dirty print heads. All modern printers have a mode that can be run to check and clean the printer's print heads, as well as other internal equipment used in the printing process. If you use your printer often or have had it for more than one year, we recommend running the printer's cleaning function. Consult your printer's documentation for details on how to run the cleaning function, as it differs for each printer brand and model.
Ciko
Canon Pixma MX456 Driver Download
May 14, 2014 | Canon PIXMA MX452 Wireless Office All In...
WILL ONLY PRINT EVERY ALTERNATE LINE OF TEXT & TEXT BOX BORDERS
Doesn't sound like your printer hardware. Try printing something other than your text document. If the page comes out clean/perfect then it means your printer is having a problem understanding your text document via print program translation. Otherwise try converting your text to pdf and print a sample page, if it works then again problem with software/printer translation.
Nov 24, 2013 | Epson Stylus CX3810 All-In-One InkJet...
I cant seem to print text. i can only print graphics. i recently put in new ink cartridges, tried to print a page of only text and the pages were blank. tried to print another page with text and graphics,...
Have you tried printing text in different colour if that works the black jets are blocked- try running the cleaning cycle to clear (it may not use black ink in graphics)
Nov 15, 2010 | Brother DCP 130C All-In-One InkJet Printer
Looks like a braille text
Open the HP Printer Toolkit (this software was installed from the CD-ROM that came with the HP printer) and run a "cleaning cycle",
because some of the ink-jets are clogged, which results in the "all-white" horizontal lines, where some part of that line should be black.
Jan 05, 2010 | HP Photosmart 7450 InkJet Printer
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
Sep 28, 2009 | Canon i850 InkJet Photo Printer
Text has shadows
Run the print head clean wizard in the control panel under printers/faxes section. If that dont work run the alignment wizard. One of these most likely fix it.
May 24, 2009 | HP PhotoSmart P1000 InkJet Printer
MY X1240 will not print the text .
Did you run test page AFTER new cartridges installation?
Please print text from different programs: Noterpad, Wordpad, Office word, excell, Browser etc..
If you see text in some other program check settings in "text not printing" program : MSWord has a setting in Options blocking texts.
If you never see a text, check "Printer Preferences.." different from "Printer Properties.."
Let we know if fixed by scoring this solution or tell us results for any further support.
Feb 22, 2009 | Lexmark X1240 All-In-One InkJet Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
CX6600 horizontally cuts text
Change the colour of the text to print each colour The same text once in each colour- then you will know what the faulty colour is. Download this utility www.ssclg.com install it and learn to use it. Also go to www.fixyourownprinter.com and take a look At #Epson printers there
Jun 16, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Canon BubbleJet i560 InkJet Printer Logo
old marine
old marine
