Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
Delonghi pac l90 air filter
I have been looking for a filter for this a/c for some time and noticed that you said u found one on that website but cant seem to figure out which one. Could you please help me?
    Problem Solver:
  • 9 Answers
Call 800-865-6330.  The white accordion 3M Filtrete filter is $37.95, and is NOT available on the Delonghi website.
Posted on Jun 08, 2008
I called the number 800-865-6330 and they said I could only buy the filter from them (distributor Fox international). It costs me $48.90 including shipping.
It seems you can get it from an online source as well for $50.09 including shipping: http://www.appliancefactoryparts.com/airconditioners/helpcenter/breakdowns/delonghi/delonghi-pacl90.html
Posted on Jul 09, 2008
2 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Delonghi Pac L90
Hoses for proper connection should have been included with your purchase. Without the hoses the set-up can not be done satisfactory. One is for fresh air supply and the other is the hot air exit hose. These are normally vented out a window. Check with the dealer where you perchased the unit from. If from a private individual contact them.
Posted on May 21, 2008
PAC L90 air conditioner keeps frosting up. The room air intake frosts up completely, blocking all the air.
Air conditioners frost up when there is a lack of air flow. Clean the filter, check if a belt is broken (if any), check that the fan spins freely, check all in ports and out ports for blockage and clean the coils with mild soap and water.
Jun 08, 2016 | DeLonghi PAC L90 Portable Air Conditioner
Does not blow out cold air. It comes on but does not blow out cold air, only has cool air
My DeLonghi PAC L90 Portable Air Conditioner does not blow out cold air,only has cool air
Jul 12, 2011 | DeLonghi PAC L90 Portable Air Conditioner
I have a pf code flashong on my a/c unit. Could you tell me what it means. I have the PAC l90
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Sep 24, 2010 | DeLonghi PAC L90 Portable Air Conditioner
DeLonghi Modle PAC L90 Very low cooling. The compressor is running
the problem is its a peice of **** and cant get a straight answer from the co,
Aug 10, 2010 | DeLonghi Heating & Cooling
PAC-L90 NOT BLOWING COLD AIR . DO YOU HAVE TO ADD ANY R22 OR FREEON TO THESE SYSTEMS
they all take refrigerant but there are other things like dirty filter or condensor coils that will cause the same problem
May 09, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Error Message
It's actually "Ft", which means "Full Tank".  The instruction manual says to drain the internal safety tank through the drain hoses.
To drain the tank, open the cover on the rear of the appliance. Pull out the 2 drain hoses, take off the caps, and let all the residual water flow out.  When all the water has been drained, place the caps back on the hoses and put the hoses back inside.
It also says you need to clean the filters and let them dry thoroughly before putting them back.
This is also the procedure for "End of Season Operations."
Hope this helps!
Jun 05, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi Pac L90
May 21, 2008 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi PAC L90
I would venture that your unit requires cleaning of the filters or at worst it may be a fan motor. Initially, try removing the front panel holding the filters and clean it as instructed in the user's manual. Should this not be corrective, i would suggest to seek the services of a qualified professional
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 24, 2008 | DeLonghi PAC C100 Air Conditioner
Delonghi Pinguino PAC L90 is flashing Lt on the display.
It is in Frost Prevention mode - the appliance will start up again automatically once finished.
Nov 18, 2007 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
736 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
