Question about GE Profile Spectra JGBP90 Gas Kitchen Range
My GE oven takes a long time to lite. When it finally does there is a small explosion sound. I already replaced the ignitor 2 weeks ago. It worked fine for about 1 week and now I have the same problem again with small explosion sound. Please anyone with any suggestions.
  • marka19
    marka19 Oct 04, 2010
    Did you check the amp draw on the igniter before replacing?
    Try this link for help with properly checking the igniter http://appliancehelponline.com/gasoventr...
If the gas valve is opening in a reasonable amount of time then the problem isn't with the igniter and you don't need to bother testing amp draw... Could be a number of things, clogged burner ports near the igniter, incorrect air/ gas ratio, incorrect igniter position (too far away from the burner), incorrect gas pressure. If you can, watch the burner when it lights from a safe distance and see if both sides are igniting at the same time or if it just builds up gas until BOOM! Ha ha, hope you figure it out, be careful.
Posted on Oct 21, 2010
GE profile Spectra gas range/oven is taking approx.20-30 min to preheat. Once it finally reaches temp. it seems to hold at that temp and maintain it. I have noticed occasional puffing sounds when it...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 17, 2011 | Ovens
GE Profile Spectra XL44 oven- Makes a popping noise while heating up
assuming you have a gas rang here sounds like a bad ignitor, too long to light causes a "popping "noise when it finally does, as well as extending cooking time and perhaps slight smell of gas while cooking, all signs of bad ignitor.when you start the oven should light bake bar in 40-60 secs. any longer, bad ignitor
easy part to replace yourself part num wb2x9154, remove bottom of oven cavity, 2 screws mount ignitor to burner and 2 wires lead from ignitor( use wire nuts provided if needed . and makes no difference which wire goes where theres no polarity.
Feb 26, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
My oven on my GE gas/electric oven is not working. I am not sure how to lite the pilot on a gas/electric oven can someone be of assistance?
heatman101
Jan 04, 2011 | GE Ovens
Have xl44 gas range. oven does not work, will not lite. Has electrical power, display works just does not lite. top units are fit has gas
Oven not Working or
Oven not Heating
Oven Problems
heatman101
My kenmoore oven won't heat. I see the orange glow at the bottom but no heat, or a small explosion before it does. Please help!
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 12, 2010 | Kenmore 33169 Gas Single Oven
I own a ge JGBS23DEMWW and it was in a flood about 3 weeks ago. Everything dried out pretty good, But the oven won't work. Then burners worked a little odd at first but after running them for awhile the...
When it comes to water damage, any component including wires should be replaced if they were submerged in water. The damage is not always evident and failure can occur at the most inconvenient of times. The oven is not working either because the ignitor is weak or the safety valve is toast from the water. I would not try to use this in my home unless the submerged components were replaced. Hopefully you have insurance to cover your losses.
Eric
Aug 19, 2010 | Ovens
Oven not heating up to temp. Sometimes get small explosion inside when starting. Sometimes small slight gas when lighting. Top burners work fine. Model GE JGBP26GEJAWH
heatman101
gk
Aug 13, 2009 | GE JGBP26 Gas Kitchen Range
Igniter is on, gas is released, a small explosion occurs in oven
no the little boom before it lites is normal mine does it all the time
Dec 04, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven igniter causes small explosion
Sounds like the ignitor is worn or mispositioned or the gas mix is wrong.  Could also be a worn burner.  Don't do this yourself unless your fire insurance is up to date.
Nov 16, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas stove burner/oven noises
too much air on top burner ,delayed ignition on oven ,ignitor not lined up properly or check gas presure may need regulator adjustment or replaced. gas 784
May 12, 2008 | Ovens
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
266 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
