Question about Samsung HL-S5087W DLP TV
My Samsung HL-5087W will shut off on its own. I was told to change the lamp, which I did. I t was fine for a few months, and then started to shut down again. I recently purchased an original equipment "Phillips" lamp and the problem was immediate. Still does the same thing. I am thinking the lamp mau not be the problem. Any suggestions
  • Samsung Master
  • 5,138 Answers
Ballast Board it is what Powers Lamp on.
Encompass Parts Distribution 1-800-638-3328
If all Runs are running then replace the Ballast.
Posted on Oct 04, 2010
I have a 50 inch DLP samsung and it wont power on after making a lot of noise (I replaced the lamp) worked fine for a few days now the red light and the right side green light is blinking. any sugge
The answers above are correct. It's either the lamp or the color wheel. Testing the lamp is pretty straight forward. Use an Ohm meter to see if the it's filament has continuity. It's unlikely that a good color wheel would fail immediately after changing the lamp. Look to see if some wiring is out of place and rubbing the wheel causing the noise you described. A jammed but otherwise good color wheel would cause the TV to shut down and display an error code.
Sep 12, 2014 | Samsung HL-S5087W DLP TV
Had check fan no 2 on tv. I replaced. The bulb is about 6 months old as well. I power on both fans are working the bulb comes on but the tv shuts off after a few seconds before the picture even comes on....
U recheck the tv projection lamp connections,the door latch and the lamp door closed properly and tightly.Yes,if the tv projection lamp LED light indication "LAMP" word it is still flashing or staying on the tv projection lamp some how dying again.The tv projection lamp should be replacing it again.
Sep 02, 2011 | Samsung HL-S6188W 61" HDTV
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
52" Samsung DLP
It is unlikely that you can do anything yourself.
It sounds to me that there is a power supply problem that has steadily gotten worse and that cannot be confirmed remotely, it must be done on site by an equipped professional.
May 13, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HL-R5067W no picture or sound.
I have an HL-R5067W  no picture, no sound.. What is the solution
Feb 23, 2008 | Televison & Video
Samsung DLP TV HL-R5667W shuts off intermittently
Afraid there is no simple answer to this. This set has multiple things that could shut it down, one may be the balest needs a upgrade , this could be why it seems to be eating lamps. Another is what sounds like a fan is a color wheel , these have known problems of failing, and when this happens sometimes they shut down the set. And finaly does the set have good ventalation, overheating can cause huge problems with this set
Feb 13, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P4663W
could be the lamp, and is about time for a new one
http://fixyourdlp.com/blog/?cat=4
Jan 15, 2008 | Samsung DLP HL-P5663W 56" TV
You will need to have it diagnosed if you do not have the service manual, or the knowledge of how these circuits work. I can tell you to replace this or that but it would be a guess! You need to start measuring the voltages on the ballast circuit, as I have seen door switches, fan sensors, heat sensors cause all of your symptoms as well. Good Luck
Jul 24, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HL-S5087W DLP TV Logo
432 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
