Question about Canon PIXMA iP2200 InkJet Photo Printer
I am trying to figure which ink cartridge my canon uses
    Brigadier General:
  • 10,406 Answers
Access the manufacturer's web-site:
http://www.canon.ca/inetCA/serviceDetail?m=load&id=3&sid=15&mid=0002200171&type=S
and download the Quick Start Guide:
http://gdlp01.c-wss.com/gds/2/0900005372/01/iP2200qsg_en.pdf
to get the part-numbers for the BLACK and COLOUR cartridges.
Posted on Oct 04, 2010
What is error e5 in mp 198 printer
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly..
  • In certain models of Canon Pixma printers such as the Canon MP160 and Canon MP150, you may receive an E5 error when trying to print. In this state, you will not be able to use any of the functions of your printer. The error itself is an ink cartridge error. It may be that you are using generic or off-brand ink cartridges in your Canon Pixma printer. Canon Pixma printers do not work with other brands of print cartridges; invest in Canon brand ink cartridges and this should take care of your problem.
  • Nov 18, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
    Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black...
    Canon PIXMA MX850 Multi Function Printer Printer Canon MX850 will not print from... Answer Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink... (More) Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black cartridge and not the large black cartridge? Thanks
    Sep 30, 2009 | Canon PIXMA MX850 Multifunction Printer
    Finding the ink cartridge
    Look on the mfr's website for instructions on how to replace an ink cartridge.
    Don't forget to rate the advise!
    http:www.aa1consulting.com
    Jul 31, 2009 | Canon MX300 Office All-In-One Printer
    Replacing cartridges in canon pixma mx 310
    Go to this page:
    MX310 Support
    Click on the "Support & Service" tab. In the "Search Our Knowledgebase" block, type in replace ink and click "Search".
    There should be a link at #1 dealing with installing ink cartridges. Click on the link and it will show with pictures and animation how to remove and install them.
    Thanks for using Fixya.
    Mar 30, 2009 | Canon PIXMA MX310 All-In-One Printer
    I want to refill the ink cartridges (black 30 - colour31) myself....how do I do it?
    Filling is easy - but messy. I use No 40 cartridges for my pixma ip2200.
    For the black cartridge, carefully remove the label. Drill a 2-3mm dia. hole in the depression in the top. With a syringe fill, using about 10ml of black ink. Plug the hole with a suitable bung and away you go!
    You will however lose the ink level indication as it is not a genuine cartridge - but that is unreliable anyway.
    Don't refill more than a couple of times as the foam inside the case eventually perishes and all the ink runs out.
    Whilst the cartridge is out of the printer give the jets a wipe with a wet tissue. This is usually quite effective in removing dried on ink.
    You can do the same with 41 colour cartridges but it is a bit more tricky locating the correct place to drill.
    Good luck
    Apr 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
    Cannon IP1880 Cannot detect Cartridge
    press the resume button 5seconds(this disable ink cartridge monitor..
    Mar 20, 2008 | Canon I990 InkJet Photo Printer
    Ink tank
    Users having problem like ink cartridge is only partial used, but error code appear to check ink cartridge, maybe trying to taking out and putting back, it works sometime and problem occurs again,
    • By replace a new ink cartridge will sure help as the partial used one would be faulty already, and if you are using Canon ink cartridge, do call up Canon to report the issue and they will exchange a new ink cartridge for the faulty partial used cartridge as it due to the unique feature that Canon has build on the ink cartridges not properly done, which resulted to be faulty. Canon's purpose is to prevent the usage of 3rd party ink cartridges.
    Mar 05, 2008 | Canon Pixma MP500 All-In-One InkJet...
    MP500 ink tank cannot be recognized error U043
    Same problem - two solutions I found helped me work out mine. One said contacts needed to be cleaned and it worked to use a Q-tip and alcohol or just click it in position several times until it recognizes the cartridge - this may work. Another said that they got it to work by installing a brand new cartridge - cool, but I have one full of ink it won't recognize. So I pulled the little circuit board off a used cartridge (like you need to do with some refills) and put it on the cartridge that it wouldn't recogrnize - works great. Still haven't figured out how to get it to acknowledge ink levels though. Canon really should be more consumer friendly since these problems seem to be intended to compel the use of proprietary cartridges.
    Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
    Canon Copier
    TRY UNINSTALLING THE DRIVES COMPLETELY  THEN REINSTALLING THEM.........mAKE SURE YOU HAVE THE SAME EXACT CARTRIDGE
    Oct 09, 2007 | Canon BJC 8200 InkJet Printer
    Canon PIXMA iP2200 InkJet Photo Printer Logo
    old marine
    old marine
