Question about Samsung SF555P All-In-One Laser Printer
Samsung -- can't fax to certain numbers...but we can receive faxes from that number
tom19511
  • 1601 Answers
SOURCE: receiving a fax
Faxes fail intermittently or with only one fax number
  • If static is present on the phone line, fax communication may fail. Have the phone line checked and serviced by the telephone company (or have the other party check their line). Phone line quality is the most common reason for intermittent fax failures. Some older locations and buildings have inadequate phone system wiring.
  • If you are trying to send a color fax and it fails, try sending the same machine a black and white fax. Normally the fax will detect that the other fax is not color capable and will offer you the option to send the fax as black and white but this might not always be the case. Do not send color faxes unless you know the other fax machine is capable of receiving color faxes.
  • Check the phone cable from the wall jack to the fax. It should not be coiled or longer than necessary. Coiling the cable can cause cross talk or echo on the line. Signal strength and quality can be lost with long cables.
  • Make sure the phone cable routing (and any cables not plugged into the same jack but sharing the same line) is not near any electrical appliances (electric motors, fans, kitchen appliances, or televisions). Many of these devices do not have sufficient electrical shielding and can induce electro-magnetic force (EMF) onto the phone line. Computers are usually shielded sufficiently and do not cause this problem.
  • Do not use a call-waiting service on the same line connected to the fax machine. The click sound caused by an incoming call can cause the fax to fail.
  • You can block certain faxes on some models. Verify that the telephone number of the sending fax is not blocked in the faxing software. This is usually located in the Fax History.
Posted on Nov 12, 2007
SOURCE: samsung scx-4521f fax memory received but never print out.
In 3 second make combination on you Samsung 4521F 'Menu'-#-1-9-3-4. You will enter in tech menu. Select 'toner'-new toner-yes. You will receive faxes. It really works.
Posted on Mar 03, 2008
SOURCE: HP Officejet 6310 - fax error code 350*
buy a new fax!
Posted on Jun 03, 2008
SOURCE: Fax not printing
may be you are having tonner empty error
press menu(*) #1934 menu(*) select new cartige then u will able to receive fax to print
jignesh
Posted on Sep 27, 2008
SOURCE: received fax in memory but not printing
pls solve my problem sir
Posted on Feb 21, 2009
Trying to send a fax--it rings and rings, but never connects.
Are you certain you are faxing to a valid number. First verify by using another number that is a known working number and ask if it is ringing on the reception fax.
Feb 15, 2011 | Samsung CLX 3160fn All-In-One Printer
Setup FAX...
Plug a phone cord into the LINE port of your machine. Ideally it should be a dedicated phone number, but you can share a line.
Sending a fax is just like making a phone call.
Load your original face down , dial the fax number, press send or start.
Receiving will be automatic.
Mar 15, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Fax not going out/coming in
connect a phone with 4521 in the back side jack of phoneout,
for outgoing fax
place original in the adf or glass for fax
Press hookdial and dial your sending fax number in 4521 after number dialing pull the phone handset to ear when you leason fax tone from the dialing number press start button to send fax.
for incoming fax (in not automoated)
press hook dial and press start to receive
Mar 01, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Can send but not receive faxes
No identification is not the problem. It sounds like you have it set to "manual receive" rather than "auto receive"
Jan 28, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Receiving a fax from a certain number
Does the other party have a DSL phone line?
Aug 09, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Same Number for Fax and Telephone
The fax is designed for use with an answering machine, the greeting for which must be no longer than 15 seconds. If voice mail in this case is referring to answering machine, be certain that the message is as indicated.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Mar 29, 2008 | Canon FAX-JX200
Incoming fax
THE PHONE LINE HAS DISTURBANCE ,PLEASE CALL TELEPHONE COMPANY  TO CHECK...
HAPPY FAXING
OMNIPRESENT
Oct 15, 2007 | Samsung SF-531 Plain Paper Laser Fax
Finding a fax confirmation in memory
you can get a prinout of last certain faxes received or sent(appx 20), if the number is among them, it's your luck happy faxing omnipresent
Sep 20, 2007 | Brother MFC-8220 Fax
HP fax 1010 - receives on LCD but never prints fax
Can you receive from other numbers? Can you brother xmit to other numbers? Can you xmit to him?
Feb 02, 2007 | HP 1010 Plain Paper Inkjet Fax
Samsung SF555P All-In-One Laser Printer Logo
210 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
