Question about Cycling
How to adjust gears gears sounds as if they are about to change gear while out cycling
  • Al Kupchella
    Al Kupchella Oct 04, 2010
    I assume this bike has index shifting. What kind of shift levers and derailler does it have?
    Genius:
  • 1,788 Answers
Your cable is stretched, pull it tight, if you have the tools.
Posted on Oct 04, 2010
Adjust cycle gears
Chain shifter or derailleur is improperly adjusted. Take to nearest bike shop for service
Aug 05, 2014 | Shimano Ultegra BB-6500
Vito 1.9 manual second gear will not select
Sounds like 2nd gear synchro prob but check gear change cable adjustment first
Apr 15, 2014 | Mercedes-Benz C-Class Cars & Trucks
How do I get the gears to work again on my Schwinn Mesa GSX Mountain Bike?
The shift cable is likely too loose, but there are multiple items to tighten, lubricate and adjust on just the derailleurs, let alone the rest of the bike, before it's safe and ready to ride. I would suggest you get some assistance from a more knowledgeable friend, a bike co-op or a bike shop.
May 18, 2017 | Cycling
Renault trafic gearbox cable adjustment
After fitting the cables! You need to adjust the GATE cable as each gearbox has slightly different wear... One cable selects the gears.. The other is responsible for the smooth gear selection! Sounds like your out of line mate! Theres an adjustable thread on the GATE cable! Keep adjusting til it selects smoothly! JOB DONE SAAAAAAN!! :-)
Apr 24, 2012 | Renault Cars & Trucks
From 4 gear to 7 gear every 6 to 7 pedal it skips like changing gear mountain bike
Hi michaelcook1....
Sounds like you need to adjust your derailer on the back of the bike, it may be out of adjustment and causing the chain to slip.
Please take time to rate me
Aug 18, 2011 | Cycling
The gears are not changing to the right gear but i tried to change the gears to see if it will change back where it should be but it didnt. on my handle bars gears dile is saying 3 and 7 but the gears are...
Release your gear selector cables; position your chain on the 1st.or lowest gear
for both the derailer and, pedal gears.
Adjust your cables tighten and, test (some bikes use the highest gear to adjust from.
Jul 03, 2011 | Mongoose Exile 26 Men's Full-Suspension...
Harsh gear changes up and down
sound's like it need's a clutch, to test this put the bike in first gear and with both fron't and rear brake's applyed try to move the bike, it should stall out or it will slip telling u it's time for a new one
Jun 05, 2010 | 2006 Harley Davidson XL 1200 C Sportster...
1975 75 horse johnson stinger wont idle in gear or run in gear
sounds like the reverse sensor switch is stuck in lock mode
check the switch
Aug 03, 2009 | Boating
Very Noisy Warmup cycle with my ML1210
put your ear closer to printer to detect source of noise, put all gears out and check each one and reassemple them, I hope you solve your prob.
Dec 28, 2006 | Samsung ML 1210 Laser Printer
Cycling Logo
35 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
