Question about Proform XP 580 Trainer Treadmill
I just put together my treadmill and all it does is lights up from the console and that's it nothing else
Open up the motor compartment. Do this with the power off. Slip onto your wrist an anti-static band and clip it to the painted surface before discharging the transformer. The way to discharge a transformer from the motor compartment is to move the belt slowly. Now after all the power has been discharged, you welcome to get close to the PCB (Power Control Board). Inspect the board for burn't cable connections, also pull off any wires that may look like that there has been a power surge. IF you unit is plugged into a surge protector with other plugs into it, that is a bad choice. All treadmills should have their own power source and a amperage of 20 amp breaker to your treadmill. Check to see of the reed switch or the rpm sensor is 3 business cards away from either the motor itself or the front roller. IF this doesn't help, you may need to call customer support for your problem. Serial Numbers and phone numbers are usually located down at the base in front or if it is a folding treadmill, underneath it after folding it up. If you still need additional help call on us and we could help you find the problem. Now if you go into the motor compartment without the anti static strap, you may avoid any warranty associated with your treadmill. So please advise. Call us so you can workout tomorrow (805)377-1263. http://www.thegymdoctor.com
The Gym Doctor
Posted on Oct 04, 2010
Console turns green. Why don't buttons function?
If you wish to get some details; check the site linked here. Pull up older posts. Check for treadmill articles.........
http://electro-medical.blogspot.com/
Mar 28, 2016 | Exercise & Fitness
Keypad doesn work
the red light should only blink when it is running. does the incline work? if nothing works most likely a console issue
Aug 11, 2014 | Proform XP 580 Trainer Treadmill
Light switch turns on when cable plugged in; however, the treadmill is not starting. Please help. Nothing is coming on the console.
You need to be on the console for it to start. (I presume you are on it). Make sure the screen and console are properly connected.
if this is a new device, call the service technicians, they would know best. This device has a known problem with the console.
May 22, 2011 | Life Fitness F3 Folding Treadmill
T3 - It slows down then speeds up, has mind of its own.
It sound like the Motor Control Board is failing call Life Fitness @ 1-800-351-3737 they will give you additional information and locate a servicer in your area
Jun 12, 2010 | Life Fitness T3 Treadmill with Advanced...
Won't turn on at all.
If you have no lights, check the main harness that cary power to the console. Check connection at both ends.
PS Always check outlet to make ssure you have 120 volts.
Jul 24, 2009 | Exercise & Fitness
Replace Switch error message
It was the emergency tag that you attached to yourself when you run (in case you fall over - the belt then stops etc). i had not connected it properly
Jan 25, 2009 | Life Fitness F3 Folding Treadmill with...
Proform XP 580 Trainer Treadmill Logo
219 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
