Question about GE (PSS26MSRSS) Side by Side Refrigerator
Model No. TBF-18 Dear Sir, this product have given me a very efficient and satisfying services for the last 25 years. I do realize there are much more latest advanced refrigerators. It hurts me to do away with this one.For the last four days,it does not cut off.The defrost cycle is okay.As per by your Step-By-Step Repair Manual I carried out from 1 to 7 steps.Only difference I came across is the ideal temperature should be 40 degree.f But it showing 46 degree. The Freezer compartment should be 8 deg., it is showing 16 degree.So, I would appreciate your most valuable tips to solve this problems.
  • 213 Answers
SOURCE: GE PSW26M Artica Cooling and Ice Maker Problems
on the back of the frig is a small rectangle panel. inside that panel is the motherboard that controls the whole refrigerator. thoughs boards have been nothing but trouble. one of the problems it causes when it goes bad is the problem your having. replace the board to fix it
Posted on Nov 30, 2007
  • 13 Answers
SOURCE: GE Profile Refrigerator (Model #20) w/freezer on the bottom
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop ice buildup internally, especially if the air vents at the back of the freezer are blocked by frozen food. Once that happens, that ice can interfere with the cold air circulation booster fan that runs when the freezer temperature is too warm. Then you get a LOUD buzzing noise from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the fan. You can turn the fridge off for a while (with the food removed so it doesn't spoil), and/or get a hair dryer and heat the inside back of the freezer, until the ice melts and falls away from the fan. (Just be careful not to block the nozzle of the hair dryer, or it may burn out from overheating!)
But the ultimate solution is to buy another refrigerator, one that is NOT a GE! And that makes me sad, because GE used to make GREAT refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
Posted on Jan 04, 2009
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
woodchuck789
  • 4070 Answers
SOURCE: variance in freezer compartment temperature
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the control board.
Posted on Sep 04, 2009
  • 10 Answers
SOURCE: GE ARCTICA Refrigerator, M/N PSS26PSTA - poor cooling
possibly low on gas
Posted on Sep 13, 2009
What years was the marlin model 36 lever action .22 made
The Model 36 was introduced in 1936 by Marlin Firearms as an improved version of the Model 1893. Around the time of the First World War, Marlin dropped the "18" and started calling the Model 1893, the Model 93. But no significant change in the gun's design took place. In the period between the wars, metalurgy was changing, as were manufacturing techniques. So Marlin upgraded the Model 93 and re-designated it the Model 1936. This moniker lasted only one year, and in 1937 it became the Model 36.
Model 36s were made until the Second World War. In 1948, the Model 36 was redesigned and modernized again and was given a round bolt to replace the square . The model number was again changed to Model 336. Lots of versions and lots of small changes have been made since, but variations of the Model 336 are still in production.
Pete
Apr 06, 2017 | Firearms
Paid for goods plus express delivery but company does'nt send them
  • Disclaimer
  • Purchasers of cigarette/tobacco must be at least 18 years of age. By selecting any of the product categories, you are legally confirming that you are 18 years of age or older.
Contact Us
Thank you for visiting Tobaccoonline.co.uk, Contact us for prompt and efficient customer service.
Email Support:
info@tobaccoonline.co.uk
Tel: /Non UK Customers/:
+44-20-707-843-40 From 3:00 PM to 11:00 PM London Time (Monday-Friday)
Tel: /UK Customers/:
020-707-843-40 From 3:00 PM to 11:00 PM London Time (Monday-Friday)
Tobaccoonline
BCB Bachstrasse 1
CH-9606 Butschwil
Switzerland
contact them..
Feb 18, 2014 | Cooking
Sestem is not using up salt and will not flush the lines when it is set up to .
Hi Joey,
There could be several reasons why your softener is not using salt. If it has a Demand Control the turbine that meters the water may be blocked and stuck so the softener doesn't realize that you are using any water, so it won't try to regenerate.
Your injector may be plugged, although this would cause the salt tank to become more full with each regeneration.
If you initiate a manual regeneration and regeneration does not happen you may need to replace the softener.
Knowing what make, model and age of your softener would help greatly in assessing. The best quality softeners last 15 to 18 years unless you have an Autotrol Turbulator in your softener, in which case add 25% more time; 19 to 23 years. There are a few brands that don't seem to last longer than 10 years...
Steve Scott CWS, CI
Sep 03, 2013 | Pentair Water Dispensing & Filtration
Ge Refrigerator Model TBF 16V Not cooling like it was how do I fix problem?
REFRIGERANT MAY HAVE DEGRADED AND YES CLEANING COILS AT LEAST EVERY SEASON HELPS.........IF ITS THAT OLD MOST ELECTRIC CO. WILL PAY YOU FOR THE OLD FRIDGE TO ALLOW THEM TO DISPOSE OF IT...HERE IN OHIO THEY PAY $75 CASH JUST TO ENCOURAGE YOU TO BUY ONE THAT'S MORE EFFICIENT THOSE OLD CLUNKERS USE AS MUCH AS 4 TIMES THE AMOUNT OF ENERGY THAN A NEWER ONE....THINK GREEN
May 23, 2012 | GE Refrigerators
I have an old (25 yrs or so) through the wall Whirlpool ac. I plugged it in and it runs and cools but it is noisy. Sounds like the fan is hitting or something. When I switched from Hi cool to Low cool...
A through the wall AC unit that has lasted 25 years or so? That's amazing and unheard of !!!
iI it's tripping a circuit breaker, there's an electrical problem with one of the circuits, within the unit and that can be dangerous. Certainly repairing it is an option. But, at 25 years old, I doubt that there are many parts for that model left in existence. Not to mention that the cost of troubleshooting it, parts and labor may cost almost as much or more, as a new Energy Efficient unit would cost.
You have to admit, you got your monies worth out of it over the past 25 years. So, if it were me making the decision, I'd opt for a new Energy Efficient model, with the same cooling capacity as your old one.
Hope this helped you. Please let me know. Thanks.
Jun 17, 2011 | Whirlpool ACC108PS Air Conditioner
Somehow my tanita ultimate scale has been switched from pounds to stones. How can I get it back to pounds?
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Mar 15, 2009 | Health & Beauty
VA721 Won't turnoff
Check for board and other parts on eBay.
Jan 12, 2008 | ViewSonic VA721 17" LCD Monitor
MOBILE KG 300 NOT REPAIRED BEFORE LAST 10 DAYS
sometimes you just need to be patient they may be waiting for parts or replacement stock.
please remember it is only a phone not a body part
Nov 16, 2007 | Nokia 6233 Cellular Phone
GE (PSS26MSRSS) Side by Side Refrigerator Logo
110 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
