Question about Crosley Washing Machines
Washer overflows on any water level selection
Machine overflows on intial fill as well as rinse cycle
    Genius:
  • 1,073 Answers
Check the pressure tube from the tub to the water level switch for a hole or crack in the tube, if none found replace the water level switch
Posted on May 27, 2008
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Kenmore 44832 hot water won't stop.
If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve Adefect in the water-inlet valve may mean that it's no longer able toshut off completely when the electricity has been turned off to it. Ifthis occurs, the valve may leak and drip water into the clothes tub. Intime, the water may accumulate substantially. If this happens, you needto replace the valve.
Water-level switch Adefect--or an obstruction--in the water-level switch may mean that itcan't tell the water to shut off. So the machine overflows. This switchsenses the water level in the clothes tub. It's usually a diaphragmdevice with a small, clear tube attached between the switch and thebottom of the washer's outer tub. As the water level in the tubincreases, the pressure on the air in the tube increases. When thepressure reaches a certain level, it activates the switch, shuts offthe water, and signals the timer to begin the agitate cycle. You caneither clear any obstruction in the tube or replace the water-levelswitch.
Aug 03, 2008 | Kenmore 44832 Front Load Washer
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Fills with water till it overflows especially in rinse cycle no matter what water level setting
most probably cause is water level/pressure switch or h hose.  either needs to be replaced or hose needs cleaning or came disconnected..
Jul 20, 2010 | Kenmore Elite 45986 Front Load Washer
Washer will not stop filling and overflows.
A possibility is the pressure switch that senses water level is bad or the tube that connects it to the outer tub is split or loose and leaking air. If this is a timed-fill rather than a level-sensed fill, the timer may be in trouble. The washer top needs to be raised up to look for the level switch.
Remove the agitator and watch the plastic hub at the top of the shaft to see if it moves when the washer is set to wash. If it does, remove the plastic hub and see if it is cracked or the interior splines have been torn--if so, replace the hub.
Aug 14, 2009 | Washing Machines
GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Mar 23, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Washer continues to fill until it overflows
I had same problem today. It was just a tube disconnected from the water level sensor. Raise the top of the washer and look on the left side of the tub. There should be a plastic tube running from the water level sensor to the control panel. Make sure it is connected. If not simple reconnect the tube and you should be good to go.
Feb 01, 2009 | Maytag PAV2300 Top Load Washer
Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Apr 20, 2008 | Washing Machines
Washing Machines Logo
190 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
