Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I bought my whirlpool cabrio automatic washer with 6th sense tech. in 2007 and if I could trade it for my old agitator I would! From the very beginning of purchase clothes don't seem to get as clean, it is always getting unbalanced no matter how I move and distribute bulky items. Any suggestions? Thank you.
aborcass
  • 2651 Answers
SOURCE: Washer won't fill, rinse or
F50) Motor StalledF then 50 flashes when the motor rotor position sensor (RPS) senses no rotation.•
i would call manufacture with the issue your having and demand they cover the problem as youve seen this same problem listed in multiple locations on the web(seems an ongiong issue with that model
Posted on Apr 07, 2008
SearsTechToo
  • 261 Answers
SOURCE: Whirlpool Cabrio WTW6600SW1: Won't drain
Yes a warranty is good on these machines and the first visit will justify the cost. Ld is long drain and can be caused by two problems. One is junk in the pump and the second is a drain hose inserted past the water level in your pipes. Simply stated when the machine drains you should here the water hitting the drain. If you pull the hose out and there is a water line on the hose it is inserted at least that much too far. Another detail is to make sure you use he soap as the old stuff foams too much for these machines.
Posted on Sep 20, 2008
  • 89 Answers
SOURCE: Machine moves two feet when washing bulky items
make sure the shipping bolts where removed from the washer and make sure the washer is completely level
Posted on Jul 10, 2009
  • 30 Answers
SOURCE: WTW6800WL1 CABRIO TOP LOAD WASHER, 6TH SENSE TECH
you may have a bad bearing seal assy
Posted on Feb 21, 2010
TheMobilian
  • 8220 Answers
SOURCE: F-1 F-1 Code Comes on.
Cabrio page 66 F-1 control failure replace main control
Posted on Aug 16, 2010
Whirlpool 6 Sense
I don't have the answer you are looking for but I will tell you I bought a set of Whirlpool Washer & Dryer 9 yrs ago and they were a nightmare. After replacing the boards in both my dryer once and washing machine 2-3 times, I packed them up and got rid of them. If you will start to look you will see all kinds of lawsuits against Whirlpool. Can't believe they are still in business.
Feb 19, 2015 | Whirlpool Cabrio High Efficiency Electric...
It is new and it will not even start the drum rotating in the sensing (initial) start up
The drum doesn't rotate in the sensing stage. This is when the washer is determining how much water will be needed based on the weight of the items in the washer. Once it has been determined, the water will go into the machine and THEN the agitation will begin.That's why the lid locks during the sensing stage: so we don't keep adding another item or two because that will throw off the calculations the machine is making when it's "sensing." My Cabrio is less than a year old and I still want to open the lid to see if there's enough water in there. But that's no longer necessary with all this new technology.
I hope this helps you out! If it does, please come back to Fixya and rate my advice. Thanks!
Jul 29, 2011 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
I keep getting the F50 code and I also got the SD code a couple of times. I followed the manuals directions and pressed pause/cancel and it still came back. We also unplugged the washer for about 30...
The "Sd" or Suds Detected error means that you used too much detergent. Reduce the amount of detergent that you use, and properly measure it.
When you receive the "F50" code, it means that the motor position sensor does not sense that the basket is moving. Remove any remaining packing material from the tub.
Hope this helps.. :)
Jun 09, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine motor not turning when loaded but turning when empty, and it's getting hot.
Inspect the rotor position sensor for loose or frayed wires. The washer tub and motor are all suspended on 4 rods. See page 59
More about the rotor position sensor is on page 57 of your service manual.
Whirlpool Cabrio Washer with 6th Sense Technology.pdf
Google Docs. 16 megs. Printable version.
Was this helpful?
Sep 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a f50 fault code on my cabrio washer it won't spin or agitate.
F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation. ? Does basket turn freely? If not, make sure bottom shipping pack has been removed. Determine cause of friction.
Apr 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer won't fill, rinse or agitate; washer stops, first with F50 code, then F__ Code. This washer was installed 1/28/2007 and nothing has been changed in it's use or location. This is a Cabrio Automatic...
Apr 06, 2008 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
71 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
