Question about Packard Bell iMedia SL 9553 (P660401806) PC Desktop
Display panel WHen i click on control panel and go to dispaly i get a message 'Display control panel as been disabled@
    President:
  • 2,351 Answers
If you are using Vista, click on the link below & follow the instructions.
http://www.vistax64.com/tutorials/154714-display-settings-enable-disable-changing.html
If you are using XP click on the next link.
http://search.microsoft.com/results.aspx?mkt=en-US&setlang=en-US&q=How+to+Enable+or+Disable+Changing+Display+Settings+in+XP
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
Posted on May 27, 2008
How do you remove that warning message
Windows Vista
In newer versions of Windows, User Account Control (UAC) is implemented to warn users when they are about to complete an action on the computer that could cause damage.
However, these warning messages can become bothersome. Disable UAC to prevent warning messages from being displayed constantly as you use your computer.
Click "Start," then click "Control Panel."
Double click "User Accounts."
Click "Turn User Account Control on or off."
Remove the check from the box, and click "OK." You may need to restart the computer to complete this change.
Windows 7
Find the search box at the top of the window and type "User Account Control" into it. This will result in a link labeled "Change User Account Control settings." Click the link.
Move the slider to the bottom of the window to disable UAC warning messages completely or to a position in the middle of the window to disable warnings in only certain situations.
Hope this helps
Oct 29, 2012 | Dell Dimension E510 PC Desktop
System administrator disable the display control panel
You may encounter problems trying to change your display settings if you have a certain policy set to prevent you from doing so. If you try and run the display control panel applet either by right clicking on the desktop and selecting properties or clicking on Display from Control Panel you may receive the following message or something very similar.
Your System Administrator disabled the Display Control Panel
To fix this problem you can perform a simple registry fix.
  1. Start the registry editor by clicking on Start, Run and then type in regedit and click Ok.
  2. Browse to HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System
  3. If you have an entry for NoDispCPL, double click it to open it
  4. If not you can create it by going to the Edit menu and selecting New and then DWORD value
  5. Enter a name of NoDispCPL and press enter
  6. Once you have this entry you should double click it and set the value to 0
Sep 26, 2011 | Computers & Internet
I have an hp pavilion dv2000 it has a sound for i can hear that it starts-up but no display....what do u think is the problem plz help me....
If you can start in "safe mode", go to "control panel" then, find "device manager" and right click on it. Find "dispaly adaptors" in the list and click on the box at right beside this. It should drop down and how your device. Right click on it and you should see a window showing, "enable" or "disable". If it shows "enable", click on that and you should be set.
Mar 15, 2011 | HP Pavilion dv2000 Series Laptop Full...
How do i disable the onboard graphics card on the GM5084?
You can go to the devices menu and at the top of the menu screen are two computer icons one is to activate and the other is to shut down or disable it. You can also right click and disable it. Devices is located XP on the desktop right click and go to properties. Select device programs or you can find it on 7 in the control panel.
Jan 30, 2011 | Gateway GM5084 PC Desktop
When i double clicked cricket2005.exe which was installed,iam getting a message "Cricket2005.exe has encountered a problem and needs to close. We are sorry for the inconvenience".
That is because of your display.
you can:
1. Click Start, and then click Control Panel.
2. Click Appearance and Themes.
3. Click Display.
4. On the Settings tab, click Advanced.
5. On the Troubleshoot tab, move the Hardware acceleration slider control to the third position (from the left), and then click OK.
Note The following message is the description for this position:
Disable all DirectDraw and Direct3D accelerations, as well as all cursor and advanced drawing accelerations. Use this setting to correct severe problems with DirectX accelerated applications.
6. Click OK to close the Display Properties dialog box.
Please click on this link for more info:
http://support.microsoft.com/kb/835262/e...
Dec 27, 2010 | Computers & Internet
I go through all installation steps OK but when I click on icon to start program I get message "NGMAG2 has encountered a problem and need to close." Other attempts state that program has been installed.
you can:
3. Click Display.
http://support.microsoft.com/kb/835262/en-us
Please leave me comments if you need furthur information, Else please RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 24, 2009 | Broderbund The National Geographic...
Toshiba tecra 9100 video output
Try reinstalling the video driver, make sure you have the latest correct version (ie. XP or Vista).
You might need to download the video driver from the Toshiba WEB site, and make sure you select the correct model laptop.
Jun 20, 2009 | Toshiba Tecra 9100 Notebook
I've been using my MP830 with Windows XP for years without any problems. I have all of the current Windows updates. I'm now getting this message: "prestopm.exe has encountered a problem and needs to close"
It has to do with your display.
Try this...
3. Click Display.
Disable all Direct Draw and Direct3D accelerations, as well as all cursor and advanced drawing accelerations. Use this setting to correct severe problems with Direct X accelerated applications.
May 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
KTC screen gone bad
Hello sir/madam
Go to Display in control panel, Then go for display settings
Then click identify select display one or two....if it is not detect display ..click detect ..
click windows key+p there it shows multiple monitors ,extended display,duplicate dispaly
Oct 03, 2017 | Computers & Internet
Whirlpool Gold electric range.
Hello delmonico
Welcome to Fixya,
You said, when turning on the self clean option, after 1 minute, I get E 1 F5 on the display panel. What do I do?
Try this .
Turning off the power to the range at the breaker for 5 minutes and see if this will reset the system.
Display shows messages
Is the display showing a letter followed by a number?
Depending on your model, press OFF/CANCEL or CANCEL/
OFF to clear the display. See “Control Display” in the
“Electronic Oven Controls” section. If it reappears, call for
service.
Let me know how it goes.
Thank You,Huuum
Please remember to enter a rating!
Oct 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Packard Bell iMedia SL 9553 (P660401806) PC Desktop Logo
37 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
