Question about Frigidaire GLTF2940ES Front Load Washer
When it gets to spin cycle it move all over the placy bang into wall ????
    President:
  • 670 Answers
Check to see if the machine is level and all the 4 legs are making good contact with the floor. If the machine is level, check to see if the machine spins freely. Open the door and check the drum. It should be hang straight in the opening. Spin the drum by hand and listen for any strange noises. It should spins quietly without any banging noises. If that check out, remove the lower access cover and look at the wash drum. There are two shock absorbers. If they look damaged, they will need to be replaced.
Posted on Oct 04, 2010
Whirpool duet model#WFW9300VU02Why doeswasher clangs and bangs in the spin cycle
the spider gear is broken,it would be cheaper to replace the washer than have it repaired,you either overloaded the washer or used to much detergent,you should only use two tablespoons of h.e. detergent in a front load washer or you did both,if you look at the back wall it looks like a peace sign,that's where the gear is
Jun 23, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Samsung WF231ANW VRT Loud and aggressive spinning, banging against the wall
You have to make sure the load size is the exact match to what size your load is.
Aug 22, 2012 | Samsung WF231ANW 3.5 cu. ft. High...
Banging noise during spin cycle
weight not distabuted in washer move cloths around so its even
Feb 10, 2010 | Washing Machines
Loud bang during spin
Unplug it and plug it back in after a min. Try to put it threw a rinse spin cycle. Delicate option has a shorter rinse spin time.
See if it suds up, when you hear it trying to drain lift up the drain hose to the wall. It is the gray tube that has the elbow bend, might (should) be hooked to wall. If it isn't moving a good amount of water the machine isn't draining.
Aug 04, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Feb 09, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Our washer shakes badly at the spin cycle
look on the back and take the shipping pins out there are 4 bolts on the back of the machine the only only ones that are 1/2" socket size or 7/16" pending on the machine.
Jan 04, 2008 | Washing Machines
Banging when spinning,
it is supposed to move freely but ofcourse not bang. what brand is your washer so i can give you a solution to the banging problem
Nov 25, 2007 | Washing Machines
Frigidaire GLTF2940ES Front Load Washer Logo
438 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
