Question about Food Mixers
Sometimes mixer runs when turned on, sometimes not
My mixer was running just fine, but now sometimes it runs and sometimes it does not.
You might need a new cut off transister or you may get rid of the old one, it is located under the transformer covers in yellow tape.
Happy cake making..
Posted on Mar 03, 2009
    Scholar:
  • 81 Answers
Sound electrical to me.... what kind of mixer ?
Posted on May 31, 2008
I have a KitchenAid KSM90 Stand Mixer and it will only run on Speed 8. Any ideas?
Your description is very incomplete. Does it not start turning until the lever is at position 8 or does it run at high speed from the moment it starts at position 1?
If it's not starting until position 8 then the problem is probably mechanical and will require some parts to be replaced or adjusted.
If it starts on high speed at position 1 then it's likely you need to replace the phase board under the back cover at the top.
Whatever you decide to do check the carbon brushes first as worn out brushes can sometimes create funny speed problems.
Oct 18, 2017 | KitchenAid Food Mixers
Kitchen Aid K5SS mixer runs for a little while then stops
Check the carbon brushes, they could be worn out. Apart from that you will be pulling it apart to find the burning, that's where the fault will be.
Jan 22, 2017 | KitchenAid Food Mixers
Why won't our kitchenaid stand mixer run?
He rdnowak:
I am sure #10 in the highest speed, but are you saying it will only run at #10? if so I would start by removing the cover again. Hopefully no parts are missing. Make sure the selector switch is moving things on the board if possible. I mean if you can move it with you finger you should be able to move it with the selector lever. Sorry for the trouble but I have never taken mine apart I just clean the out side. I do no this. Sometimes I must take something apart and reassemble them several times before getting them to work the way they are supposed to.
Best of luck
'RR
May 15, 2014 | KitchenAid Pro 600 Stand Mixer KP26M1X-...
Mixer works fine with speeds up to 6, but changing to 8-10, speed stays the same.
Sometimes can be caused by running too fast on the lower speeds. Should be 13 to 15 revolutions in 15 seconds on speed 1 then a slight increase only on speed 2.
Aug 01, 2013 | KitchenAid K5SS Heavy Duty Commercial...
Got a hobart mixer model h600-t cutting off and kicking breaker,it runs sometimes for about 5 min. when the ladys are mixing bread,checked amps,not under a load
If you can access the brushes you may want to inspect them. If anything but the carbon brush is touchiing thhe armature. It with trip a breaker.. Unplug it before accessing the brushes < -- my disclaimer :)
Oct 27, 2009 | Hobart H600 Stand Mixer
Sometimes when I turn my kitchenaid stand mixer on it won't move, like its slipping, but if i give it a gentle push it runs. it doesn't do it all the time. What could cause this? It looks like when you...
if it has an internal saftey clutch this could be worn out or requiring adjustment , another cause could be a sheared woodruff key which fixes the drive pulleys on to the various shafts/gearbox etc
Oct 20, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Mixer turns sometimes
The smell is the motor overheating and intermittant run is worn brushes in the motor
Jul 04, 2009 | KitchenAid K45SS Classic Stand Mixer
Whining noise in all three speeds.
There is only one bearing in the back a an A200, the rear motor bearing. Page 12 -- Otherwise I'd look for something rubbing the motor. (wire, capacitor shield) The two back side covers are easy to remove, two screws each.
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
The timer is also in the link. The part is not cheap, but easy to install.
Jun 20, 2008 | Hobart A200 Stand Mixer
Food Mixers Logo
93 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
