Question about Eureka Enviro Steamer 370 Upright Vacuum
Envirosteamer 300 leaking water. Older yellow model. I put water in it and as soon as it heats up, all the water leaks out the bottom, and it barely gets warm! It worked fine before. Could it be seals need replacing or something? Thanks!!
2 Suggested Answers
  • 161 Answers
SOURCE: Water leaking
The water tanks on this unit have had a very bad history of leaks. Most of the repair people had never heard of this unit, but one did, and had a spare set of tanks. If the unit is still under warranty, it is worth your while to get a replacement unit. Call Eureka, and ask them how to get a replacement unit, especially if you are having more than one issue with the unit (such as leaking, no heat, broken upholstery nozzle, etc.). I had success in sending back the serial number plate and a detailed list of my problems. They sent me a new unit, and I was able to get at least one unit working properly. Some repair men may be able to fix leaks in the seals on the tank. Hold the tank up and if it leaks, well you got your problem! Eureka will not solve your problem, I've discovered they like to let their service depots handle their junk. Most service depots can give you a solution if they are worth their salt. If the service depot can still get tanks, go that direction. If no replacement tanks are available, call Eureka for a whole unit.
Posted on Dec 23, 2008
I have a Hoover V Steam Vac model F7412. The tank for the clean water and cleaner fluid leaked out the bottom. I purchased a new tank but something in that area is still leaking. I know it is not the...
My clean solution tank is leaking from the bottom, too. It is not a hose or a valve. The clean solution tank is leaking in-between the clear plastic walls of the solution tank & the grey plastic bottom that are connected, together. I was thinking of caulking it all around the bottom where the clear plastic sides join the grey bottom plastic. I can't get into ordering a new one (spending $) unless Hoover will send me a new one for free. Purchased at Kohl's in Massapequa, NY in June 2008. There's a one year warrantee AND the directions say to EMPTY the solution tank after each use. Which I normally do because the tank runs dry.
Aug 08, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Trigger pin is stuck or something else is wrong. why is it constantly leaking water as soon as I plug it in?
You will need to provide more information as in the model AquaMate you are using as I can't determine which one by your information. You can also call and speak with a tech. at 800-640-2033.
Rainbow Vacuum Cleaner Systems Repair Center
Mar 28, 2014 | Rainbow E series Canister Wet/Dry Vacuum
How do i get my bissell to stop leaking water?
The rubber gasket on the bottom of the 2-in-1 tank is probably lodged in the base of the unit. It should be connected to the nozzle on the bottom of the 2-in-1 tank. You can pull it out of the base and reattach it to the tank. This should stop it from leaking. The formula tank on the back has the same gasket so you can pull that out and see how it should fit on. Hope that helps.
Apr 05, 2012 | Bissell 2X Proheat 9200 rug cleaner
Severe water leak at the bottom when turned on.
It sounds like the tubing that is suppose to be hooked to two spray nozzles has come loose. You will have to take that dirt tank off, then turn the machine upside down and take the two screws out that hold the hood on from the bottom by the brushes, and then turn the machine back upright and take the screw from the top out. You should be able now to take the hood off and see all the tubing exposed. There is only one tube that goes to the spaying part in the front and see if it needs to be pushed back onto its' barbed fitting. Put that back on and put the hood back together. That should get you going.
Dec 02, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Leaking
Could be that the despensing tank has melted and deformed at the connection point. This is what happened to me when I put in really hot tap water. The heat allowed the connection (where the water/soap outlet is) to deform when using it. Now when I fill the tank and place it in the machine the water just leaks out all over the place with no control.
If you look at the bottom of your tank, where the water comes out, you may be able to see that the plastic is mis-shaped or deformed slightly. It probably doesn't take much for the seal to be broken.
TEA
Sep 22, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
Total leak issue
There maybe a tube that has come disconnected, depending where the water is leaking. If at the bottom, then take the top cover off and check for a loose tube. If it is leaking where the tank sits on, could be a tube under that platform, or there is a rod inside the handle, when you squeeze the trigger, it pushes a diaghram where the tank sits, If the rod is going up and down, then it is probably ok, but the diaghram on the reservior asm(#48). is staying open allowing water to go thru all of the time. You may have to replace that reservior asm.
Aug 26, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Water leaking out from bottom of 7901
That part can go bad, but I have found more often the a water line came loose. Take out the 6 screw and the flow indictor cap, remove the top, then inspect that area. If you find what the problem is, fix it then when you put the top back on, make sure the piston is on the bottom of the smart mix valve and that the knob is in the water only spot, then push the top back on. If you need to replace the auto-load receiver, the part # is 2140710 and you can order from a local repair shop.
May 30, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell
Check the belts first, if ok, does water squirt out of the hose nozzzle, if it does then the heate in the handle asm. is clogged where the tubes hook up to it. If no water squirts out, the the pump isn't working. Pull the top cover off, check all tubes to make sure there is no clog. Make sure the tubes are routed right so as not pinch one, also make sure the piston is mounted on the smart mix knob. and the knob is in the water setting before putting the cover back on. The cap for the flow indictor is leaking are or screwed on too tight. The seal at the bottom of the tank is not on the tank and is missing or sitting in the hole where the water goes.
Dec 23, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Hoover Steamvac Widepath 6500 leaks
You didn't give your model number, but if this is a V2, you may have a crack in the tank, alot of times it is underneath the seal on the bottom. Or the plunger at the bottom of the tank is stuck open or missing.
Dec 02, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Eureka Enviro Steamer 370 Upright Vacuum Logo
171 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
