Question about Bodum 's C-MILL electric blade coffee grinder in matt chrome
Grinder is stuck in "on" mode.. Have tried to clear the hole but not working.
I have this problem also, has anyone worked out how to fix it yet. Thank you
Posted on Mar 03, 2011
How do i fix the error 8
Display ERROR 5 or ERROR 8 Is A Technical Malfunction. To Fix It Switch "OFF" the device at power switch 1 for at least 10 seconds. Then turn it back on. If that doesn't work try 60 seconds or reboot the device for at least 1 minute. Good Luck.......
Jun 10, 2014 | Bosch TKN68E75UC Benvenuto Stainless Steel...
Grinder blocked Saeco Caffe Charisma
If the problem is only just stuck then you should try to rutn the gringing adjustment to more gross grinding and first try to remove all remain coffee beans from grinder, with the use of avacuum cleaner try to clean everything from the grinder beans and grined coffee. Then try to make a coffee if it continue to be stuck turn for more gross coffee grinding clean with vacuum and try again is the grinder is only stuck then this will work if after all these the grinder does not turn then you will need to remove it and also you might need to replace it.
May 10, 2012 | Saeco Caffe Charisma Espresso Machine
The grinder on my DeLonghi seems to be stuck. It makes only a noise but not s bean is ground and one can hear it is not turning. Any solutions? Thank you
Likely a foreign object is blocking up the grinder. Remove all beans and run at coarsest grind to try to clear it, chase it through with more beans if necessary. If this does not clear it then the top burr of the grinder assembly can be removed after disassembling the machine. Mark the grinder coarseness cogs before moving them to assist reassembly. Moderately difficult procedure.
Aug 11, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Continue to get beeping after taking out basket, emptying water, re-inserting basket and making certain lid is clicked shut. Thoughts?
All the parts have to be in place, including both the removable grinder unit and its clear cover, even if you're using pre-ground coffee.
It also requires that both the top lid and the front "door" (to the basket area) are clicked shut, and that the basket and its cover are both in place.
One thing to check carefully is the clear cover to the grinder unit. There's a rubber-like "nub" that seems to actually control the switch, which tells the machine that the grinder unit is properly installed. If that rubber-like nub is missing (and unfortunately it IS possible to remove it, particularly during cleaning) ... that could be causing your problem. If you see a hole in the top of that clear cover... you're missing that "nub".
Sep 14, 2010 | Cuisinart DGB-600 Coffee Maker
I CANNOT REMOVE THE GRIND BASKET TO CLEAN IT.
I suffered with a stuck grider unti for a long time and just solved the problem..... Remove the filter basket and through the front door look up twords the back left. You can see where the grinder unit sits. There is a slot area where you can stick a screw driver under the grinder unit and pry it up. Do this in a jiggling motion and make sure you are well under the grinding unit, doing so on the edge of the grinder unit underneath will not give you enough suface to work with, in fact you will just bend or crack the edge. Looking in from low on the front (kneeling on floor with unit on counter, worked for me) will let you locate where the screw driver or smal pry tool needs to go. Mine was stuck for a very long time and No amount of pulling or prying from the top would work, I made it pop out in a matter of seconds using this technique from the bottom! Good luck, I'm going to finish my cup of coffee now! :-) Steve
a little cooking oil on the shaft before you insert the grinder will help, spray on pam works well and is easy to do...
Jul 01, 2009 | Cuisinart Thermal DGB-600 Grinder
GAGGIA syncrony compact coffee grinder motor is
Remove the brew unit and to the left of that is the the discharge area for the grinder, make sure that hole is clear, then adjust grind 1 number coarser, and check machine.
Jun 07, 2009 | Gaggia Syncrony Compact Coffee...
Cuisinart coffee maker grinder stuck in machine. Can't remove to wash
Same problem and I'm the husband that always got it unstuck...... until this morning. I read somewhere that putting the whole machine in the freezer will work. I did and the grinder just lifted out without any pressure at all! My wife was laughing at me when I was looking on line for a solution but she just smiled when it was removed.......
Aug 30, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Take apart
My grinder went from bad to worse and finally stopped grinding (with the motor still buzzing but absolutely no grinding). Knowing I had to do something or throw it away, I pulled the clear plastic bean reservoir upward and separated it from the grinder body. I looked down the hole where beans go down to the grinder and found packed coffee ground blocking the hole. I cleaned the whole thing, put the reservoir back, and my grinder now works like new :-)
Oct 27, 2007 | Braun KMM 30 Electric Burr Grinder
Coffee Grinder not working
the grinder is most likely stripped and needs to be replaced:-{
Jul 23, 2006 | Saeco Caffe Charisma Espresso Machine
Bodum 's C-MILL electric blade coffee grinder in matt chrome Logo
199 people viewed this question
Top Bodum Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Peter Meixler
Peter Meixler
Level 1 Expert
ray gallant
Are you a Bodum Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
