Question about Panasonic PT-50LC13 50" Rear Projection HDTV
I JUST BROUGHT A REPLACMENT LAMP, BUT THE RED LAMP LIGHT STILL ON AND IT SAY REPLACE LAMP AND RESET THE LAMP HOUR METER
    Sergeant:
  • 171 Answers
If you all ready reset the lamp timer and closed the access panel you may now be having a problem with your ballast board it might be too weak and that is the reason it does not turn on this ballast boards are not that expensive they range from $60-$80dls
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE
Posted on Oct 04, 2010
Hi i have a sony lcd projection kdf-e50a12u and as i turn it on the green light flashes for a few minutes untill it turns to red along with the light next to it and stays red?
Sir check the lamp of your projection if already damage, if damage replace the lamp and reset also the lamp hour meter. Remove the screws to open the panel labeled "lamp" on the back of the Sony TV. Remove the screws that hold the lamp in place inside the TV. Pull the lamp out. Let me know what is your observation to the lamp so I can guide you. Good day and best regards.
Sep 15, 2011 | Sony KDF-E50A12U 50" LCD HDTV
I have a Mitsubishi WD60737 TV! TV powers on and then powes off! Red light is blinking! HELP PLEASE!
Try to check the lamp if already faulty replace same type of lamp and be sure to reset lamp hour meter after replacing lamp good day and best regards.
Sep 04, 2011 | Mitsubishi Televison & Video
We have the Akai 52"
Replace the lamp, after you replace the lamp reset the lamp hour meter good day and best regards.
Aug 28, 2011 | Akai PT5492S 54" Rear Projection...
I have a Samsung HLT5076S DLP Tv and when I turn it on I get a blinking Green Light for a couple of Mins. Then after awhile all three light start to blink. The standby light is Red and the timer and the...
It is the lamp but try to check the filament of the lamp if defective because if the color wheel is defective you will hear a whirring noise. Try to check the lamp if defective replace it and if you replace the lamp you should reset the lamp hour meter, feel free to send feed back good day and best regards.
Aug 22, 2011 | Samsung HL-T5076S 50 in. TV
Replaced lamp bulb on panasonic pt52lcx66, reset lamp hour meter and red light is still on. Any ideas?
Pull the lamp out and install again and reset with the orignal remote control. (not a universal)
Jun 02, 2010 | Panasonic PT-52LCX66 Projection Television
Replaced the bulb yesterday- the projector does not recognize the change- getting a default message to change it... And there is a strange smell (we also changed the filter (after 5 yrs)
copied from manual
select the menu - default - clear lamp hour meter to reset lamp usage hours.
Note when the lamp exceeds 2100 hours (3100 in Eco mode) the projector cannot turn on and the menu is not displayed if this happens do the following while in 'standby' to clear values for Remaing lamp Time and lamp hour meter for vt670/470 press the help button on remote control for a minimum of 10 secs When the lamp clock is reset to zero the lamp indicator goes out.
May 14, 2010 | NEC Replacment Lamp Projector Lamp for...
Red lamp lite on and how to reset lamp hour meter?
turn your tv on. on the tv it self press and hold the " - " like your turing it down. then on your remote press and hold the number " 0 " for five seconds. it should say the the meter has been reset to zero.
Jan 29, 2010 | Panasonic 52LCX1516 52 in. Television
Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Lamp Hour Meter
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Lamp hour reset to many popular projection TVs are given.
Mar 03, 2017 | Televison & Video
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
48 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
