Question about Health & Beauty
I want to buy motor brushes for vita master treadmill 8712WM.
2 Suggested Answers
parts4treadm
  • 69 Answers
SOURCE: Need 2 x brushes for motor
you can get new brushes here
http://www.partsfortreadmill.com/parts-for-treadmill/treadmill-motor-replacement/treadmill-motor-brushes-20x9x22-h-mm.html
and you can check here for treadmill help in general
http://www.treadmillsrepair.co.uk/
http://www.partsfortreadmill.com/repair/repair.htm
Posted on Dec 08, 2014
My belt is lubed and properly tightened. The belt will slow down intermittently randomly while running without anyone on it. Model NTL2495.0
first of all check the drive belt is loose or not. Drive beit connect with the motor and roller of the treadmill. its not possible to see the drive belt out side. you can only see it if you remove the motor cover. if its loose the try to tighten it. if its not the problem then the treadmill motor have some problem. Either the motor is faulty or the carbon brush is faulty. There is 2 carbon brush inside the motor which is replaceable, its used to take the voltage to the rotary part (armature) of the motor. If the contact with the rotary part and carbon brush is poor the this type of problem can occur. tyr to change the brush. Here i have added a video which demonstrate how to change the carbon brush of the treadmill motor. It not the exact model you have. but almost all treadmills have the same type of motor. even after replacing the carbon brush the treadmill shows the same problem then you have to charge the motor with a new one .
http://electro-medical.blogspot.com/
Fitness repairs
Nov 13, 2015 | Exercise & Fitness
It was moved upside down. Turned on, it worked. Turned on again, now motor wont start.
some times treadmills are liquid cooled with oil, which is probably what you are seeing. The reason for it not working however might be due to a failed motor (typically the brushes). The brushes can be replaced IF IT IS A BRUSH STYLE MOTOR, if it is a brush-less motor, further diagnostics will be needed, or replace the motor.
Jun 18, 2015 | Exercise & Fitness
Where will I buy a gearworks model jm05-002 treadmill motor
I doubt you need a new motor if you have not checked the brushes. Hard to put the clips back in place though. I am having trouble doing this. You may have a Horizon treadmill. If so you can down load info from there web site. Although USA web site. UK bit stuck on that.
Oct 05, 2012 | Exercise & Fitness
Where can i buy GREENMASTER DC Motor GMD105-1 3.0HP for replacement in my Reebook TR-3 Treadmill?
The only place I know is smooth fitness stocks them. I put new brushes in mine, and then soldered teh commutator connections-----it is working now, who knows for how long !
Mar 01, 2011 | Reebok Exercise & Fitness
Treadmill (Vision Fitness T8500) turns on, motor doesn't run...
open motor shroud and inspect all connection on the motor control board see if all LED 's are lit except that light up when incline motor is moving up or down. then check the two connector coming from the drive motor to the board sometime over time the two connector will have a cold soldier I would move them to see any excessive movements of the pins then hit start and see if there is any belt movement. Last but not least unplug unit and check the motor brushes if they are less than 3/8 in in length replace them. Call them @ 1-800-335-4348 they under their parent corp. Johnson fitness.
Feb 28, 2010 | Exercise & Fitness
Motor immediately shuts-down upon start-up
check the brushes, if the machine turns on normal but the engine does not work can be a problem with the brushes, check the connections or wires that go to the motor drive card. Also check the speed sensor is often a magnet
Feb 05, 2010 | Bodycraft TR1180 Light Treadmill
Health & Beauty Logo
44 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
