Question about Gateway E-475M Notebook
Whenever I try to start my laptop, it runs a check of the C drive and then, afterwards, I can't get to my desktop without getting a blue sreen saying there is a problem with my C drive.
    Scholar:
  • 110 Answers
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Description of Safe Boot options
  • Safe Mode (SAFEBOOT_OPTION=Minimal): This option uses a minimal set of device drivers and services to start Windows.
  • Safe Mode with Networking (SAFEBOOT_OPTION=Network): This option uses a minimal set of device drivers and services to start Windows together with the drivers that you must have to load networking.
  • Safe Mode with Command Prompt (SAFEBOOT_OPTION=Minimal(AlternateShell)): This option is the same as Safe mode, except that Cmd.exe starts instead of Windows Explorer.
  • Enable VGA Mode: This option starts Windows in 640 x 480 mode by using the current video driver (not Vga.sys). This mode is useful if the display is configured for a setting that the monitor cannot display.
    Note Safe mode and Safe mode with Networking load the Vga.sys driver instead.
  • Last Known Good Configuration: This option starts Windows by using the previous good configuration.
  • Directory Service Restore Mode: This mode is valid only for Windows-based domain controllers. This mode performs a directory service repair.
  • Debugging Mode: This option turns on debug mode in Windows. Debugging information can be sent across a serial cable to another computer that is running a debugger. This mode is configured to use COM2.
  • Enable Boot Logging: This option turns on logging when the computer is started with any of the Safe Boot options except Last Known Good Configuration. The Boot Logging text is recorded in the Ntbtlog.txt file in the %SystemRoot% folder.
  • Starts Windows Normally: This option starts Windows in its normal mode.
  • Reboot: This option restarts the computer.
  • Return to OS Choices Menu: On a computer that is configured to starting to more than one operating system, this option returns to the Boot menu.
An environment variable is set when you use one of the Safe Boot options. The environment variable is SAFEBOOT_OPTION. This variable is set to either Network or to Minimal.
The default Microsoft VGA driver is used for display at 640 x 480 resolution and in 16 colors. You must log on in all modes by a domain or by the local Security Accounts Manager, depending on which Safe Boot mode you select.
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue, and then replace the file. To do this, follow these steps:
  1. Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  2. Type the following command, and then press ENTER: sfc /scannowThe sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
To determine which files could not be repaired by the System File Checker tool, follow these steps:
  2. Type the following command, and then press ENTER: findstr /C:"[SR] Cannot repair member file" %windir%\logs\cbs\cbs.log >sfcdetails.txtNote The Sfcdetails.txt file contains details from every time that the System File Checker tool has been run on the computer. The file includes information about files that were not repaired by the System File Checker tool. Verify the date and time entries to determine the problem files that were found the last time that you ran the System File Checker tool.
  3. Type the following command, and then press ENTER: edit sfcdetails.txtThe Sfcdetails.txt file uses the following format: Date/Time SFC detail
This information was obtained from Support.microsoft.com
Posted on Oct 04, 2010
My sreen become blue
Does your screen go blue whenever you try to turn the computer on? Are there any words on the screen? Have you tried starting in safe mode? Tell us which computer model you have.
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Mar 01, 2014 | Microsoft Windows 7 Ultimate Edition...
Blue sreen error in my acer laptop
go into bios,set it to defaults then install. try a fress partition, delete the old one and create a new one, there might possibly be artefacts from a previous bad install. I would test memory/hard isk for errors before I started installation if it has been running badly, problems here might be causing the BS, as might motherboard issues
Good Luck with it
Oct 06, 2012 | Acer Aspire 4741 4741g 4741z 4741zg 4743...
Start up problem.need to turn on and off many times.after turn on run for a while ,blue sreen appears ,then everything goes off
Try pressing F8 repeatedly on startup and at the options screen, if you get the choice, choose repair my computer. If not, choose safe mode. This loads only the basic drivers and files, so if the machine starts in safe mode, there is probably an issue with a driver or a corrupt registry file. If you have the recovery disc, you can try booting it from the CD drive and do a startup repair. Choose language settings and then choose repair your computer.
Apr 06, 2012 | Acer Computers & Internet
Windows sont run displays on sreen that i need to instal windows root system32/hal.dll and it wont start on any of the safe modes and it wont detect usb
If it cannot access any of the Advanced Boot Options, you may need to reinstall a fresh copy of the Operating System. However, try to run a hard drive diagnostic software to check if your hard drive has bad sectors.
For advanced troubleshooting on how to reinstall the file (system32/hal.dll) without doing a clean install, check the link below.
http://support.microsoft.com/kb/945380
Hope this helps.
Jun 09, 2011 | Toshiba Portege M200 Notebook
The sreen has locked-up saying uninstall anti-virus, etc, but I can only restart using the start button, which gets me back to same blue screen
Your laptop is infected by the viruses that's why you are getting blue screen. To fix this problem you need to format your laptop. Get a windows cd and the motherboard installer.
Mar 25, 2010 | Dell Inspiron 1525 Notebook
STOP: c000021a {Fatal System Error} .. 0xc0000005
The first thing you should do is back up the HDD, Remove the HDD from your Laptop, you find the lid that opens the HDD access slot under the laptop or ask someone who knows how. if available there are aftermarket 2.5 HD enclosures that lets you install the 2.5 in.hdd of your laptop via a usb. you can plug the usb to a desktop PC and backup your files. then reformat your hdd. reinstall the hdd to your laptop. replace your memory ram which causes the blue screen with a new ram, reinstall the OS.
Jul 07, 2009 | Dell Vostro 1510 Laptop Computer PC...
The moniter doesn't work when i turn it on
do you get a blue screen if so its the blue sreen of death and you will need your back up recovery to reboot your laptop but i would suggest rebooting and if that doesnt work ring the people you bought it off and get it replaced
Jun 08, 2009 | Advent 4211c Notebook
Blue screen shows up
usually points to the hard drive. try running the hard drive diagnostics on your Dell computer. Shut down the computer, then press and hold down the FN key, then press the Power button, afterwards, release both buttons. That should load the diagnostics for your Dell laptop. Note any error code that you may find.
Try booting in Safe Mode. If it works, chances are, it is related to a device driver
Feb 01, 2009 | Dell Latitude C800 Notebook
Gateway E-475M Notebook Logo
141 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
