Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
My hd is not turning on its just showing vertical color lines
    Sergeant:
  • 171 Answers
This is a common failure for the Optical Block your LCD have burned out you need to replace the OPTICAL BLOCK to fix this problem check out this link it will help
http://www0.epinions.com/msg/show_~threads/cat_id_~13/id_~9877/forum_id_~127
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!
Posted on Oct 04, 2010
HD TV what would cause a dark gray vertical line in the middle
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Televison & Video
My lcd only show half pic the anhother half show color lines verticals
Sounds like you have either a faulty Tcon pcb mounted top middle of the LCD, or a bad connection from LVDS lead to TCon. In alot of cases by cleaning the LVDS lead and reinsertig this solves the problem.
Feb 13, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Blue vertical line thru picture
It is called "Thin vertical lines" and change colors depending on the background color.
It is fixable but there are several components that can show this sympton.
You will need a tech to fix it in order to save money (because you do not want to buy a board you dont know if will fix it).
Possible Solutions:
Replace Timer Control Board, if it is not fixed
Replace Sustain Board.
One of those boards needs to be replaced and I wrote the most likely first.
May 27, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
42" LG Plasma with 4" vertical lines at each end
LG service is non- existent . The only solution that I can suggest is "Give a wide berh to LG products. Dont ever touch any"
Mar 07, 2008 | LG 42PX5D 42 in. Plasma HDTV
Vertical portion pixelats then forms solid vertical lines. Problem intermitent but persistant. The tv is 2 years old, if its the lcd panel is it worth repairing? I think I have the same problem with a...
Note
In some cases, there are minor defects in some parts of the screen. Points that do not light, points with
brightness different from that of the periphery, or points with color different from that of the periphery.
Some pixels will always be on or always off. Please note that this is not a malfunction. So what this says is that it's not the Plasma Cell problem, its more like a bad board inside. You will need more info like schematic and find out which area the bad part is in.
Jan 04, 2008 | JVC PD-42WX84 42 in. HD-Ready Plasma...
KDF-E50A10 Sony TV Purchased May 06
IF THIS HAPPENS ONLY WHEN USING HD SORCE THEIR IS A MODIFICATION TO BE CARRIED OUT.IF NOT THE OPTICAL BLOCK WILL REQUIRE REPLACING.
Nov 10, 2007 | Sony KDF-E50A10 50 in. LCD HDTV
Vertical flickering color lines instead of pictures
Take your set to a qualified tech you have a bad vertical ic or some cap around the vertical section is not filtering the voltage properly and your deflection yoke could also be bad.good luck.
Mar 16, 2007 | Sony PFM-42X1 Plasma TV
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
