Question about Imperial IR-6-C Elite Gas Kitchen Range
How do turn on the pilot to the oven? and how do I know its calibrated correctly? I have an LP version
  • 3 Answers
On this unit the pilot lights it's self when the oven needs heat as for checking the oven you can put a temp probe over the exhaust and it should read around 20'c less that it is set to
Posted on Feb 17, 2011
Converted HotPoint RGA720 to LP, burners and oven work fine, all pilots flames are still too high?
I have this model too and have had to replace two thermocouples because the pilot is so high it frys them. We replaced the whole modulator last time and it still goes out so I have to relight The pilot is at the lowest setting, it's a GE/Hotpoint issue that was not recalled. I do like the hot 125 degree oven for drying sun dried tomatoes and keeping plates warm.
Apr 13, 2013 | General Electric Hotpoint® RGA720PKWH Gas...
How do u change a gas stove from natural to lp?
Nearly every natural gas / LP operated appliance can be converted to work with the other fuel pretty easily. You will need to change the orifice in the burner & pilot. Contact your LP provider and they should be able to supply the correct parts / perform the labor for this job for you.
Feb 19, 2013 | Whirlpool Stove / Oven / Range Cooktop -...
Model# BWH30NLTB
Unit goes under sure heat name also.
My unit emitted unburnt gas smell the minute pilot started,
and was annoying during burner operation.
I discovered they built unit with primary pilot that had 2 ports.
They used LP and sealed off natural gas,instead turning lp/nat
knob on back activates second pilot for natural gas use.
This means natural gas goes thru LP pilot orifice and burns
slightly off during normal natural gas use(by design).
The unused natural gas orifice has 1 air mix hole and the LP orifice
has 2 air mix holes.
I carefully plugged 1 of the holes in the LP orifice and suddenly
pilot gas flame seated correctly on orifice port.Gone was the
unburnt odor of natural gas.
The typical flame in a flame appearance now was exhibited by
the small pilot,secondary pilot remained consistent with manual
picture.
Of course, to use with LP I would have to open blocked air mix
hole in addition to the other changes per manual.
Hope this helps someone with similar condition.
Dec 31, 2012 | Reddy Heating & Cooling
I have Zebra LP 2844-Z printer and the barcodes
Here are 3 suggestions.
Check that your label size definition is correct, measure your label height in mm and check that your printer driver settings match.
Perform a calibration. How?? when printer is on labels loaded and green light, hold feed key and wait for 2 blinks then release feed key. (If you release it after 1 flash you will print a configuration label)
If you are using Zebra Designer, download latest version of Zdesigner V2. Install latest printer driver V2.63. This driver & Zdesigner allows you to calibrate the printer directly from within Zdesigner. Go to File/Printer settings/ advanced options and click calibrate at bottom of page. when printer calibrates then tick the box USE PRINTER SETTINGS and printer will now work properly.
Jul 01, 2010 | Zebra LP 2844-Z Thermal Label Printer
The oven will not heat. Pilot light is glowing
Try resetting the safety valve if there is one. If there isn't you may have to turn up the pilot slightly.
Dec 11, 2009 | Kenmore Kitchen Ranges
Pilot light keeps going out when turning on oven
Sounds like the GSD. The Gas Safety Device valve needs replacing
Oct 17, 2017 | Ovens
Yellow flame after an Lp conversion
I remember having a stove with an adjustable orifice in the oven. It looked like a double nut arrangement. If that is what you find, tightening them to each other shrinks the size. Should turn fairly easy, do not force. You may also find a pilot adjustment behind the oven control knob. Hope this helps.
May 19, 2009 | KitchenAid KGST307 Gas Kitchen Range
How do i adjust oven pilot light on vulcan range
hi, there is an orfice for the oven located on the gas valve. If you are using LP gas, the orfice should be turn down all the way (counter clockwise). If you are using natural gas, the orfice should be turned out about 2-1/2 turns. Was this oven set up to be used with one gas and noe is being used with another? If so, you will need to do more then adjust orfices. Please let me know if I can assist you further.
Thaks
Vic
May 13, 2009 | Kitchen Ranges
Oven won't stay alight . has never worked from new . have checked all thermocouple connections all seem's well. probe is tight and in correct position.
To post a more specific solution you need to have the model number, but with the info you have given, I'm guessing that you have hooked the range up to LP gas and the range was not fully converted from natural to LP. If all burners burn nice, whomever converted the range may have missed one step. Many ranges with pilot lights have a small slot head screw behind the oven temp set knob which turns one way for natural, one way for LP.
Sep 16, 2008 | Kitchen Ranges
What could be causing this?
i service these ovens alot and my first guess the t-couple you already replaced.i wouldnt think its the valve.lp burns very dirty as you know,clean out the burner/pilot assmbely and see if this solves it.also take a look at it when its lit and see if the pilot is being pulled to the burner.let me know.also if the unit has a regulator on the back pull the vent plug and clean it up.
Nov 09, 2007 | Vulcan 36L Gas Kitchen Range
Imperial IR-6-C Elite Gas Kitchen Range Logo
291 people viewed this question
Top Imperial Kitchen Ranges Experts
Dan Webster
Dan Webster
Thomas Perkins
Thomas Perkins
Are you an Imperial Kitchen Range Expert? Answer questions, earn points and help others
