Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Refrigerator and freezer not cold also inside of freezer wall ice is formed. What could be the problem ? Please help.
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
Why doesnt the refrigerator and freezer not get cold enough?
You need to check a few things -
1. settings for the temperature are not set too low. Not cold enough.
2 there is no leakage through the door seals.
3. there is not too much ice formed inside the freezer walls. Needs defrost.
4. the fridge is not overloaded with stuff - not enough capacity to cool things.
5. Not enough free space behind the fridge to allow air movement for coils to cool
Please provide more details of the problem if above not helping. For example model number, is the problem happening both in freezer and refrigerator settings. Get a fridge thermometer and monitor temperature in both sections. should be 4 deg C in fridge and -18 deg C in freezer after stable operation.
Apr 23, 2014 | GE Refrigerators
Not getting cold
John can you tell me the model number? Is ice forming on the rear wall of the freezer? Here is a example photo of ice forming on the rear wall of the freezer HERE I am here to help you but you will need to help me by saying more. Sea Breeze
Jul 31, 2013 | Amana Refrigerators
Freezer not cold and forming ice in side?
Replace the defrost thermostat located on the coils in the freezer. Here is the part to order.
Dec 03, 2012 | Amana ARS2464B Side by Side Refrigerator
Why ice is forming in some items kept inside at the back of the refrigerator including the vegetable tray.
Ice at the back of refrigerator section is usually due to a fan there that has become stuck, little fan like 2 1/2" or so, the fan circulates cold from the freezer into the refrigerator. If that cold air is not moved through than it will form ice there from moisture in the air of the refrigerator section. I have had that problem a couple times, could be from something pushed against back wall and got n the way of fan blades causing fan to stop.
Apr 18, 2012 | Samsung Refrigerators
GE side by side mod 7FX20JR can't read the rest. Quit making ice and freezer side just cold. Fridge side only little cold. Cleaned out freezer-had to throw most food away. unplugged unit. Cleaned out...
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Dec 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer side is very cold but in the refrigerator not much cold.
Check evaporator fan inside the freezer
Check condensor fan underneath in back
Check for ice buildup in the evaporator coils (Defrost Problem.)
Also ice and/or frost on the back wall of freezer (defrost problem)
Check air vent for ice block from freezer to refrigerator inside the fridge.
Should have low air volume to fridge from freezer.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 07, 2010 | Heating & Cooling
Freezer is too cold, ice crystals. Refriderator
I'm not sure which one you have, but try this: Look for the area where the air passes from the freezer to the refrigerator side, in the wall somewhere between them. Make sure that there isn't something blocking the passage. This is a good place to start.
Regards,--W/D
Jul 10, 2009 | Kenmore Refrigerators
The back part of the refridgerator inside where the cold air comes out is leaking water and the back inside wall is wet?
You should fine a drain line just below the freezer level in the back. The drain line is more than likely plugged. Check the loop seal down by the drain pan under the back of the refrigerator. It may be restricted at that point. It may require a complete defrost of the freezer to clear the ice formed in the drain from a back-up.
May 28, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Water always inside refrigerator sometimes ice forms
Sounds like you might have a condensation problem. Is the fan in your freezer working? If not it's not circulating the cold air. If it is you might have frost on the lower rear wall of your freezer meaning its not defrosting like it should and restricting your air flow. Last but not least you have a damper door in the upper left corner of your fridge that allows the cold air from your freezer into the fridge to cool it, that might not be opening up. Any one of these things would cause your water problem and a warm fridge section
Dec 05, 2007 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
50 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
