Question about Vivitar ViviCam 8025 Digital Camera
Camera wont turn on after being on charger for hours. when i hit the power button a dim green light comes on. how do i charge this piece of **** camera??
    Problem Solver:
  • 11 Answers
Make sure tat charger is getting power correctly else you have to replace your charger
Posted on Oct 04, 2010
Wont start up
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Mar 23, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
My head phones wont turn on
I was so upset today i was at school and my headphones wouldn't come on and that my friend told me that many people were having this problem and would end up returning it but i got home and noticed a dim dim almost cant see red light emitting from the earphone ( also turned off my lights to see this as-well ) that you turn it on from and i realized that they obviously had power still. So i looked up how to hard reset them and it worked ! they came back on and it was amazing to do this ( it says it in your manual) you plug the headphones in to a charger, push and hold the phone button and the volume + button and that does a factory reset and it made it come on and work i was so happy.
Dec 14, 2012 | AUVIO Bluetooth Headphones
Battery was low so put in charger.laptop then turned itself off.been on charge 3 hours,still wont come on.led lights flash 3 times when pressing on button
take the battery out unplug the charger hold down power button for 10 secs replug charger back in with out battery then see if it turns on
Feb 24, 2011 | Computers & Internet
I hit the power button and it turns green for a second but then goes out. The camera and LCD screen do nothing. So I have some sort of power problem. When I put the battery in the charger the charger light...
theres no choice your battery charger is may be out and try new battery and try the power cable from the charger and connect directly to the cam if you got the original power pack/ for the green screen it can go green or bleu when the battery go low, some time that is the video processor ic...
i hope for you it just the battery....
and good luck
May 13, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
My g1 wont turn on when i try to hit the power button the top light turns blue and when i do the reset it dose the same thing
Is the battery charged? Is the charging LED showing up as normal when you connect the charger? Try charging the battery for a few hours and then try to reset the device?
May 04, 2010 | HTC G1
My iRobot scooba won't turn on after a full charge
Do you have the charger terminal, or do you have the charger that you have to take out the battery and charge. Because I have found that my base terminal charger works better than the battery charger that needs the battery to be removed to charge.If you have the terminal charger and the power light is green when it is in the charger I would start from the terminal
Jul 26, 2009 | iRobot 5800 Scooba Vacuum
Blue On G1
ok i had this isssue and figure out what to do. this is all afterm you know that you have a good charger and or battery.
1. completely turn of phone unplug charger.
2. take and put battery back in phone and plug charger.
3. hold hit camera button and power buton. phone will come on if the update was washed it will come straight on. if not you will see the blue LED dont worry yet. just keep holding for 15 sec.
4. while phone blue LED is still on hit and hold (drum Role) menu and track ball for 15 sec.
5. now unplug charger and take out battery. wait 10 sec
6. now put battery back in and leave charger off. and turn on. unless you was in middle of update and hardware failed this WILL bring your G1 back up and running.
hope this helps everyone . MIll$tronics signing out.
Mar 05, 2009 | HTC G1
Camera won't stay turned on
It sounds like weak batteries in both cases. The zoom motor takes more power than displaying pics. DON'T USE "HEAVY DUTY" batteries - they're for kids toys. Use alkaline or rechargeable, and charge the batteries for AT LEAST 15 hours, even if your charger indicates they're fully charged after 1 hour. Please leave feedback if this helps.
Jun 29, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
AHHHH!!!!
Just had the same thing- I blew out the plug port and re-plugged it in, charged for an hour, and now it turns on.
Jul 12, 2007 | Palm Zire 72 Handheld
Camera will not charge the battery
Well. Ive got the same problem only ive gone thru 3 batteries trying to figure out what the problem is. When i plug it in to charge the light turns red , then within 5 sec's turns green. It stays green but never charges the battery. After 24 hours, its still a dead battery. Im just assuming since its 5 years old that the internal charger is shot. Looking for a new camera at this time.
Aug 20, 2006 | Gateway DC-T50 Digital Camera
Vivitar ViviCam 8025 Digital Camera Logo
60 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
