Question about Microwave Ovens
Microwave oven - how to replace fuse
My oven died today when I pressed the add a minute button. It's probably a blown fuse. Where is it located, so I can check it? (Kenmore 721.66319500)
Penny
  • gary paterson Jan 06, 2009
    how can you test the transformer and so on???
  • Microwave Ovens Master
  • 9,086 Answers
You can usually find an exploded view by entering your FULL model number (721.66319500) here.
But there's usually a reason the fuse blows!
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor too.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer too.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 30, 2008
GE microwave oven fuse? no sign of power
PokMan, Check the attached links,instruction and guides on fuses and thermal fuse breaker. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Where is the fuse located and how do you replace it GE Microwave Oven
GE Microwave Fuse Thermal Fuse Breaker Parts
GE Microwave Oven internal fuse Google Search
Microwave Not Working
Microwave Oven Troubleshooting in MINUTES STEP BY STEP
Jun 11, 2016 | GE Microwave Ovens
My kenmore elite microwave stoped working completly and i have no lights on de microwave at all
Probably a blown internal fuse; you will have to remove the housing to locate it and if a replacement also blows, it's time tlo shop for a new one.
Typical of too many things today, it will likely cost more to repair it than a new one costs.
Feb 14, 2015 | Kenmore Microwave Ovens
Microwave does not start. receptacle is live. is there an internal fuse for this microwave that may have blown
If you can program the time but it will not start cooking when you press the "Start" pad, you probably have a bad door switch or door switch mount.
If the oven has no display and will not respond, it is "dead" ands it may have a blown fuse or a blown magnetron thermal cutout (TCO) or thermostat or a blown oven cavity TCO or thermostat.
You can find helpful exploded view diagrams and order parts by entering your full model number
here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components (especially an oven cavity TCO / thermostat) for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Aug 21, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our Maytag microwave died. The outlet has power.
you have to remove the cover, un-plug the power cord=
un-screw the screws located behind the unit and on the sides if any also under side if any, remove cover and you will locate the fuses and other components behind the key pad, also check slow blow or thermal fuse usually located on top of oven. NB: HIGH VOLTAGE COMPONENTS PROCEED WITH CAUTION!!!!!!!
Mar 25, 2010 | Maytag MMV4205 Microwave Oven
HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Jul 11, 2009 | Jenn-Air JMV8208A Microwave Oven
Maytag MMV4205BA microwave buzz/grind when operating then no power
you may have some arching inside where your magnatron is located.If you open the door on the right middle part there is a silverplate on the wall .If it is burned you may need to replace magnatron.if you do not seee burn marks it may still be the magnatron hope.that would be the only possible thing that would make the noise other then the mtor plate out of place.
May 15, 2009 | Maytag MMV4205 Microwave Oven
This oven does not operate any longer.
TAKE OFF THE CABINET AND LOOK FOR A FUSE THAT IS MORE LIKELY GREY AND MADE OF CERAMIC IT IS SHAPED LIKE THE OLD GLASS AUTO FUSES. NO VISUAL (GOOD OR BAD) MUST BE TESTED WITH OHMMETER FOR CONTINUITY
Apr 28, 2009 | Whirlpool MH2155XP Microwave Oven
Everything went
No reset button, but there's probably a ceramic type fuse inside. If you replace it and it blows again, then the unit needs serviced.
Safety first! Unplug before taking apart. Put back together before plugging back in (unless you know what you are doing).
Geno
Mar 06, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
266 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
