Question about Broderbund The Print Shop 23 Deluxe
Purchased Broderbund Print Shop 23.1 Deluxe. Two discs. My question is: When I install the program disc, shoud the Art disc be installed also?
Yes, otherwise you have to manually insert the Art disc every time you want to use the Art & Photos.
Posted on Oct 12, 2010
I purchased printshop 20 deluxe and installed on my computer which has windows 7 installed on it. The installation shows it was successful however when I try to run the printshop program it tries to start...
The Print Shop version 20 Deluxe for PC is not compatible with Windows 7. The newer Version 23 is compatible. This is due to software compatibility issues with Windows 7.
You can check for Win 7 Compatibility for "software or hardware" @ Windows 7 Compatibility Center
It will not run on Win 7, even when you are using the Compatibility Mode options. Too bad you have to get the newer version 23.
Hope it helps.
Mar 14, 2011 | Broderbund The Print Shop 20 Deluxe for PC
How do I access the clip art on the Art disc? I have windows 7 and Print shop 23.1 deluxe? I put the Art disc in the drive, when I look in the art gallery there is nothing there, even when I tell it to go...
try opening up the disk seperatly to the program & looking for the picture you wont then copy and paset it in but you shald find it under the menu bar in insert/ picture
Feb 19, 2011 | Encore The Print Shop 23 Deluxe Full...
Can install Print Shop 21, but when the splash
Solution
You must reinstall Microsoft .net framework.
You can do this by:
Go to the control panel
Go to add remove program select Microsoft .netframework 1.1 and remove
Also if you have the Microsoft .netframework 1.1 Hotfix select that and click remove as well.
Once both those are removed we can reinstall Microsoft .netframework from the Print Shop Install disc
You can do this by:
Insert the Print Shop Install disc
Double Click on My computer
Right Click on the Drive that contains the Print Shop Disc
Left click the open option.
Double click on the folder called Setup
Double click on the file that’s called 1033DotNetfx
This will reinstall the net framework on your computer and it should fix the issue you are having.
Nov 09, 2009 | Broderbund The Print Shop 21 Deluxe Full...
The installation keeps getting interupted because something is not configured correctly. I have tried install from hard drive and same thing happens
try to uninstall or clean all interupted installation of Print shop 23 deluxe by using perfect uninstaller.Then install it again after reboot.
Nov 04, 2009 | Broderbund The Print Shop 23 Deluxe
I get an error 1305 when installng Art Disc for Print Shop version 23. Suggestions
Problem
Error 1305 or 1304
Solution
The Print Shop® 23 Error 1305... When attempting to install The Print Shop® 23, an error that includes the message "Error 1305..." or "Error 1304..." appears. A conflict during the installation may cause this issue. Completing a clean installation of the program will help to prevent conflicts that can occur. The remainder of this note describes the procedure. Complete the steps below to reduce conflicts during the installation.
Clean the CD or DVD
  1. Place a small amount of nonabrasive, liquid soap on the shiny side of the CD or DVD.
  2. Using your fingertips and warm water, gently rub the soap on the disc in a circular motion.
  3. Rinse the disc thoroughly and dry it using a clean, soft T-shirt or lint-free towel. Do not use paper towels or tissue paper.
  4. Install the program.
NOTE: If the error message reappears, I don't know an another massage.
I hope it works for you
Aug 25, 2009 | Broderbund Computers & Internet
I Can't get Print Shop 23 to install on my Vista laptop
Hi There,
Click the Start in the lower left hand corner of your screen
Click on My Computer
Double Click The Drive that has the disc
Click Run or Install
Let me know if this helps.
Mar 29, 2009 | Broderbund The Print Shop 22 Deluxe Full...
Wasn't prompted to load image disc print shop pro deluxe 23
just go to control panel, add remove programs, select print shop (change) and select modify it will allow you to change content to hard drive and not cd.
Mar 19, 2009 | Broderbund PrintShop Pro Publisher Deluxe...
Broderbund The Print Shop 23 Deluxe  Logo
1,038 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
