Question about Car Audio & Video
Rockwood detanater amp225 wiring harness
I need to know which prong/wire goes for power, remote, and ground on the wiring harness... my pops is about to get home, PLEASE HURRY. i wanna finish before he gets here.
    Scholar:
  • 71 Answers
I'm guessing here, but power is usually a red, thick wire. seldom yellow ( old Pioneer)
Ground Is usually a thick black wire.
Amp turn on blue.(thin)
If it isn't, it ought to be.
If in doubt don't try it , check with a installer.
Fuse at battery!!!!!
Sumthin
Posted on Jun 11, 2008
4-prong to 3-prong Power Cord Conversion.
On a 4-prong power cord you have 2 hot wires, one neutral wire, and one ground wire. On a three prong cord, you have 2 hot wires and one neutral/ground wire. The difference is the on four prong the neutral wire goes to electrical neutral bus in the breaker panel and the ground wire goes to the ground bus in the breaker panel. Since the neutral and ground buses, although separate, both go to physical ground, on a three-wire setup, you are just putting the neutral and ground wire together, Most dryers actually have a place at the pigtail connection to do just that.
Sep 09, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I unpluged my amp from my car and i forgot where all the wires went i need help to hook back up right
There should be a group of screw terminals. They should say pos or (+), remote, and ground, GND, or (-). This is the power terminal. The power from the battery goes to the (+), the remote turn one (thin wire) goes to the one labeled remote (usually inbetween the ground and power wires), and the ground to the (-). RCA jacks should be labeled input and output. Plug the appropriate colors in the input ones. The speaker terminals are labeled left and right + and -. If it is a 4 channel amp, it will also have front and rear. Depending how you wired your speakers is how they will go to the amp. Follow the speaker wires to the appropriate prongs positive or negative. Hope this helps.
Aug 26, 2011 | Crunch Car Audio & Video
I plug in rockwood detanator VII and it goes to protections mode
Generally if an amp goes straight into protection, the amp is not grounded well enough. Either you should find a new location to ground the amp to or unhook the power wire from the battery, remove the ground wire from the chassis of your vehicle. Strip the paint from the chassis, since it doesn't conduct electricity, and remove any corrosion or copper shielding from the ground connector. reground to a solid metal location Can be grounded to the brace behind the back seat or to the seat belt bolt for best results.
An amp draws a lot of power, there it needs to be grounded well.
Hook back up your power wire to the battery and see if your issue is resolved.
Jul 18, 2010 | Car Audio & Video
I connected the hot wire of my stereo and ran it to the amp power and same thing as the ground and get NO power
you have to run a seperate power wire from ur battery 2 ur amp and the same 4 ur ground wire
Feb 27, 2010 | Rockwood X-Plore AMP-4030 Car Audio...
Changing dryer plug
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Oct 07, 2009 | Amana NDE2335AY Electric Dryer
I need to switch my three prong power chord to a four prong
your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Aug 17, 2009 | Dryers
Wires to radio harness
red is power black ground yellow power when key is on  blue with white strip is remote wire only need if you have system
Jul 04, 2009 | Kenwood KDC-1011S
Wiring problem
The wire you have is designed to carry 220 volts. Assumming that your socket is a 220 socket and that is what your application is the following answer applies. The black wire goes to one of the straight prongs and the red wire goes to the other. The white wire goes to the tight angle prong and The ground wire goes to the ground screw. good luck
Jan 17, 2009 | Midwest Electric 30-Amp Power Inlet Box -...
Car radio won't work
A lot of electronics equipment have two [2] types of grounds.1) Hot ground (there is voltage on this ground relative to earth ground or the car's body ground. Are you grounding properly ? Is there more then one ground wire. With a meter [ of cause all power to component are OFF!] Sometimes the ground that goes to the radio goes to the BATTERY ground directly. How meny wires come out of the radio? What colors are they? Are the wires all the same thickness?
Apr 19, 2008 | RCA Universal Remote Control
Car Audio & Video Logo
125 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
