Question about Emerson LC320EM8 32 in. LCD TV
When i turned on my tv, the color looks faded. I try to change the picture and color settings but certain colors like yellow, purple, and blue just don't really show
  • 518 Answers
SOURCE: 20" digital flat stero tv moel CR202EM8
It sounds magnetised. Is there a magnet near that side... like a speaker?
It probably needs degaussed. Many TV shops have a device that does this, at a cost to you. Also, the set degauses itself for about a second when it's first turned on after being off for a while. So it may go away by itself eventually.
Hope that helps...
Geno
Posted on Feb 27, 2008
SOURCE: My mom has an Emerson LCD Color Flat Screen TV
COLORS OF LCD SCREEN HAS TURNED TO PINK AND PURPLE WHAT TO DO NOW?
Posted on Jan 11, 2010
MattCasdorph
  • 44 Answers
SOURCE: I have a new Emerson LC320EMX 32
Similar to mine, only my tv you can change channels. We either need someones help or atleast a service manual (not user manual)
Posted on Jul 14, 2010
maatmartin7
  • 1213 Answers
Your TV is still in the factory test mode. To remove from the tech service mode try this.To exit the service mode, grab the original remote. Press the cursor left followed by the cursor right button. Now press the off button on the remote or on the TV itself. Hope this helps. Thanks for asking and show a few hands of support!
Posted on Nov 11, 2010
maatmartin7
  • 1213 Answers
SOURCE: My tv just changes colors
Your TV is in the service mode. Just try one of two things to correct this. With the original remote, press the cursor button left, followed by pressing the right cursor button. Now shut the TV off. When you power up your TV it should be fine. The second thing to try is to press the cursor button up, followed by pressing the cursor button down. Power off the TV. Now power it up and it should be fine. Thanks for asking and show a few hands of support.
Posted on Jan 03, 2011
I have a Samsung rear projection tv, the picture is faded and the colors are not crisp or clean cannot watch it like this what do you think the problem is?
If this is a CRT-type rear-projection TV, the CRT coolant fluid is probably broken down. It's supposed to be clear, but after a long period of TV operation, it turns a yellow-brown color. If you unplug the TV and remove the back, you can look into the tops of the three picture tubes. They should be a clear red, green or blue color, with no yellow-brown tint.
CRT coolant can be changed, but you need to be very good at mechanical work to do it. Besides the safety considerations (picture tubes and other parts may carry a high voltage charge even when the set is unplugged), spilling broken-down coolant on electronics is usually disastrous, so you have to be very careful.
LCD panels used in projector applications may lose contrast if they are overheated (this can be caused by failure to keep the vents clean as recommended in the owner's manual).
You would have to provide your set's model number to get more specific information.
Oct 27, 2010 | Samsung Televison & Video
Purple picture with sound
Hi, that sounds likes a degaussing coil problem,or a magnet have come to close of the tv, you will
needs a picture demagnetizer where you gone put it on the picture tube and making circle on the tube and walking back at the same time you still making circle and enlargin the circle at the same time you walk after 10 feet about turn off the demagnetizer,
that should bring at the normal color; if not thats
inside ,look for a positor or thermistor to replace
and try to dont turn the tv when the power is on
thats affect the degaussing process it work only when you start the tv on for few second..
good luck and hope that help you
have a nice days
Mar 13, 2010 | Televison & Video
Still, bright images on my PS3 change the color of my TV in areas
hi verifies if you are connecting good the video cable i mean the red, the yellow, and the white, if this dont serve you, is because your tv is to old.
Sep 19, 2009 | RCA TruFlat 27F520T 27" TV
Color on photos suddenly has a blue - purple wash with no greens
Your yellow cartridge is probably not working as your photos suggest. Remove and reinsert the yellow cartridge. Try printing only yellow color.
Your printer has a separate head for printing; the nozzle for yellow ink might be clogged. Try running a head cleaning routine from your printer software.
Sep 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Wii only shows blue, yellow and black on my HD TV
Are you trying to plug in the yellow, red ,and white cables into blue, green, and red slots? If you are you cannot because those are for HD inputs only
May 06, 2009 | Nintendo Wii Console
No color when turned on, after a while it color returns.
This is a cold solder joint in the signal section of the set. After it heats up, that problem area conducts better. Have an experienced electronic person reflow some solder on the board.
Feb 02, 2009 | Toshiba 32AF43 32" TV
RCA Pearl TH1100A backlight colors
Pp. 16-17 of your user's manual:
http://www.rcapearl.com/pdf/TH11xx_IB.pdf
Settings
Press forward to enter the Settings menu and then
press plus or minus or to highlight an item. Press play
repeatedly to change settings.
Backlight:
• to adjust the time before the display light
turns off (On/10s/20s/30s).
• to adjust the color of the display light
(Red/Blue/Green/Yellow/Cyan/Purple/White).
-Tha Mp3 Doctor
Dec 13, 2008 | RCA TH1101 MP3 Player
Red , Green And Blue.
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
May 22, 2008 | Televison & Video
Sharp aquos LC-37D4ou
What kind of connections are you using?
If component (red, green, blue) double check to make sure they are seated properly. I'm thinking it sounds like the blue one got loose.
Mar 27, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Faded and out of focus picture
Your TV has a burnt CRT base socket. Replace that, it is not a tough job, but make sure that you get the exact same type of base socket.
Jan 14, 2008 | Panasonic CT-34WX15 34" TV
Emerson LC320EM8 32 in. LCD TV Logo
126 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
