Question about Porter Cable 18 - Gauge Brad Nailer and Compressor Combo Kit
I have a Porter Cable brad nailer BN125A, at 125 PSI and depth adjustement turned to the deepest drive setting, the brad does not set flush with the surface. Problem?
  • Porter Cable Master
  • 885 Answers
A brad nailer in good working order, set to the deepest setting and using 125psi should almost shoot the brad through the wood. If you have been oiling the gun properly (three to four drops at he beginning of your work session and again in the afternoon if under constant use) then you probably have some worn o-rings inside the gun. Porter Cable makes a driver maintenance kit (PN1001 60062) for your gun that will make it work like new.
Posted on Oct 04, 2010
16 ga nails dont set flush to wood.
Assuming that the nail head not setting in and adjusting depth control does not remedy. Usually occurs when the tip breaks off. Remove the head and pull out the driver to examine tip. If tip broken or bent, replace with new or try to adjust as needed. If about 1/16 of tip broken, reshape the driver so that the tip is just slightly wider than nail head, taper the lower 1/4 inch on the side of the driver that faces the nails so that the driver will only strike one nail and reduce (shave) the size of the lower bumper so that the driver will extend out same amount that you need due to broken tip(only works if 1/16 -1/8 broke off).
Nov 16, 2011 | Porter Cable 16 - Gauge Finish Brad Nailer...
Bn125a nailer not sinking nails all the way
The depth to which a fastener is driven is controlled by the depth adjustment
knob (A) Fig. 19 below. The depth of drive is factory adjusted to a nomimal setting.
Test fire a fastener and check depth. If
a change is desired, rotate the
adjustment knob (A) Fig. 19: the
adjustment knob has detents every 1/4
turn. Rotate the knob clockwise (see
Fig. 19), to increase the depth of drive,
rotate the knob counterclockwise to
decrease the depth of drive. Test fire
another fastener and check depth.
Repeat as necessary to achieve
desired results. The amount of air pressure required will vary depending on the
size of the fastener and the material being fastened. Experiment with the air
pressure setting to determine the lowest setting that will consistently perform
the job at hand. Air pressure in excess of that required can cause premature
wear and/or damage to the tool.
Good Luck
Nov 26, 2010 | Porter Cable Cable BN125A Factory -...
How do I adjust the depth of the brad nail on the porter cable BN 125A brad nailer
Hello. To adjust the depth of the nail you have to increase or decrease the air pressure from the compressor. Look at the compressor and you will see a knob or dial that you can turn to increase or decrease the air pressure. Do this adjustment in small increments testing the nailer by driving nails into a scrap of the same material you will be driving the nails into on the actual job. Increasing the pressure will drive the nail deeper and decreasing the pressure will drive the nail less deep. Joe
Nov 10, 2010 | Porter Cable Cable BN125A Factory -...
Air is escaping from the top of the bn125a brad nailer. It won't fire nails.
it sounds like you have a damaged o ring/seal that requires maintenance. You can go to Dewaltservicenet.com and download a breakdown for this tool and also order parts for it. When reinstalling new o rings don't forget to put a little bit of grease on them so they don't roll or pinch. Let me know if you need more help
Nov 13, 2009 | Porter Cable-Cable No.BN125A...
BN200A porter cable brad nailer. have tried
check for a broken driver blade, also make sure of the proper nail guage for the tool. Let me know if this is not the case and I will find you a breakdown for the tool for further inspection.
Nov 06, 2009 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
BN125A Nailer will not fire even after rebuild kit
low air pressure may be the cause ,make sure you set the outlet to 70- 90psi
May 27, 2009 | Porter Cable Cable Brad Nailer and...
Driver cover "a" won't close
you may need to check if the driver blade is all the way up.first make sure you have the magizine open when you try to close the front latch.
May 21, 2009 | Porter Cable Cable BN125A Factory -...
Porter Cable BN125A won't set nails below surface
Not sure about the seal, but I do know the pressure has to stay up for this nailer to be effective. Try oiling the gun to free up the mechanics and don't use old nails.
Jan 23, 2009 | Porter Cable Cable BN125A Factory -...
Porter Cable 18 - Gauge Brad Nailer and Compressor Combo Kit Logo
257 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
