Question about HP vp17 Monitor
How do I switch my monitor from DVI to VGA? - HP vp17 Monitor
Click on the menu button on the monitor, then go to management, then go to Default Video Input
Posted on Jun 29, 2011
  • clarencec286 Jun 29, 2011
    Press the Menu button on the monitor, Press on the Management option, then Press the Default Video Input option and choose anyone which you wished to choose.
Fpd1775w monitor no signal
Are you using the VGA cord or the DVI? If using the VGA switch to DVI, maybe there is a short with the VGA plug inside the monitor. a VGA to DVI adapter on the back of pc should do the trick unless your computer has a DVI connection as well..
Jan 02, 2013 | Gateway Computers & Internet
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector,...
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
Feb 21, 2011 | Acer X193W LCD Monitor
I am using acer P205H monitor ,when i plug in it will start and shows acer symbol on the screen but goes blank as computer starts ,i checked all power cables they are OK ,and some switches are provided on...
that switches r made basically changing dvi to vga r vga dvi,if that switches r malfunctionig display goes to blank that means if u connect vga system will have dvi
Jan 30, 2011 | Acer AL1916W 19" LCD Monitor
Samsung syncmaster 2033sw monitor, till now i was using a vga cable for the display, but recently i bought a dvi cable and connected it. but its not detecting the display of dvi cable. if i remove the vga...
LCD Monitors having multiple inputs have option and option to select and switch between the displays from analog (VGA) or Digital (DVI) inputs. Go to the LCD menu and select input source (DVI)
Hope this helps!
CreativeTECH
Nov 15, 2010 | Samsung Syncmaster 2033SW Monitor
Just received Refurbished Advent CBE 1401. It is being replaced because power switch is faulty - but I have questions about machine. 1. When initially switched on the switch turned red is this normal? I...
1) No. The switch color should have been Green
2) No Signal on the monitor, indicates the monitor is not receiving a Video Signal from the computer.
A) Could be due to a faulty monitor cable.
Monitor cable is used on a working computer for a test,
Or,
working computer's monitor cable is used on the Advent for a test.
B) Could be due to the graphics 'engine' on the motherboard, or on the graphics card is bad.
[Graphics 'engine'.
GPU
Graphics Processing Unit.
http://en.wikipedia.org/wiki/GPU ]
If the computer is using Integrated Graphics, the GPU is on the motherboard.
(Integrated Graphics is also referred to as OnBoard Graphics. Meaning On the motherBoard)
You will know if it's Integrated Graphics, because the monitor cable will be plugged into the VGA connector, on the motherboard
http://en.wikipedia.org/wiki/VGA_connector
Since you indicate an adapter was included, to adapt to a different port (Connector), it could be a VGA to DVI adapter, or a DVI to VGA adapter.
Your monitor may just have a VGA connector on the monitor cable.
Hence you would use a female VGA to Male DVI adapter.
Your monitor may be an LCD flat screen monitor, and has a DVI connector on the monitor cable.
Hence you would use a female DVI to Male VGA adapter.
DVI
Digital Visual Interface
http://en.wikipedia.org/wiki/Digital_Visual_Interface
VGA monitors are Analog.
LCD monitors are Digital.
A computer puts out a digital signal.
If a VGA monitor is used, the computer has to alter the Digital signal to an Analog one.
This slows down the video signal.
If your monitor (In any case. Not just this one), is an LCD flat screen monitor, it is best to use a DVI monitor cable, and plug into a DVI port on the computer, if available.
If your monitor is a VGA (CRT. Cathode Ray Tube), monitor, and you have a DVI connection on your computer, using the adapter will do you no good.
The adapter just uses the contact pins for VGA, that are present in that DVI adapter, and hence the DVI connection on the computer.
You're still just getting an Analog VGA signal.
Example of a female VGA to male DVI adapter,
http://www.directron.com/dvi.html
If the Integrated Graphics are suspected to be bad, a graphics card is used in the appropriate expansion slot, for a test.
If the graphics work then, the graphics card is left in service.
After I test the monitor cable my next procedure is to suspect the Power On switch, or the Power Supply, and go to the graphics next.
The reasoning is that Power Supply failure, is the number one cause of computer failure.
The next is the Power On switch, then Electrolytic Capacitors used on the motherboard.
(Specifically, any Electrolytic Capacitors used in the motherboard Voltage Regulator Circuit)
If the Power On switch is bypassed, the diagnosis will reveal if the problem is the switch, or Power Supply.
Bypass the Power On switch, and the Power Supply comes on?
Problem is the Power On switch.
[One Power On switch I have found to fit a lot of computers. The Power On switch goes into the plastic Power On button,
http://www.directron.com/atxswitch.html ]
Bypass the Power On switch, and the Power Supply does Not come on?
The problem is the Power Supply.
The Power On switch is bypassed using a jumper wire, from the green Soft Power On wire, to ANY black Ground wire. The contact made is a brief momentary one.
The jumper wire is used at the back, of the 20, or 24-pin ATX main power cable connector.
To be continued in an additional Comment.
Jun 04, 2010 | Computers & Internet
After Microsoft splash screen the monitor goes blank except for "no signal" messages if I turn off/on the monitor. I checked the monitor menu. Under Misc dropdown the Input is empty. Clicking input bring s...
Please check whether you are using a DVI (Digital Visual Interface) cable or VGA (Video Graphics Array) cable to the monitor.The monitor will adjust automatically to the requirements of the connected cable.From the question I think you had connected a DVI cable to the monitor.Make sure that there is no loose contact between the ports and the cable.Also make sure that the proper settings on the monitor are done for the DVI cable configuration.
Mar 07, 2010 | X2Gen MV20TP Monitor
Monitor says No signal digital
Is ether the monitor or video card uses both DVI or VGA port. There may be a switch on the graphic card that changes it from DVI to VGA, often outside the card.
Also is the computer monitor set to the right setting if it can use both VGA and DVI, if using DVI (of any type) it need to switch to digital, and if using VGA it need to be set to analog. This may be a physical switch or using the settings button. (see manual how to change them)
PS: VGA port is a blue D shaped port with 15 pin holes, and DVI is a white rectangle port with one port being a line.
Mar 17, 2009 | ViewSonic VG2030wm LCD Monitor
Dvi to vga
You will not benefit from the DVI input unless you have DVI output on your computer. The great advantage of DVI is that the picture is transferred in digital form all the way from your computer to the individual pixels on the monitor. If you only have VGA output on your computer then you will never get a better picture than by using a good quality VGA cable to link that to the VGA input on your monitor.
The DVI plug is designed to carry both digital and analogue (VGA) signals on the various pins, so "adaptors" exist to allow a VGA monitor to attach to a DVI output on a computer. Monitors may also support VGA input from their corresponding DVI input sockets, but the picture quality will never be better than by using a good VGA cable because it is still not using the digital capability of the DVI interface. What's more, because you may need more adaptors and thinner conductors in the cable, you will probably achieve a marginally poorer picture than with VGA to VGA.
When you next buy a PC or a new video card, get one with DVI to take advantage of your new monitor. In the meantime, your best bet is a quality VGA to VGA link.
Sorry that's not what you were wanting to hear, but I hope it will help you avoid further frustration.
Sep 20, 2008 | Envision EN-985e Monitor
HP vp17 Monitor Logo
66 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
