Question about Gem Sound TR-150 Speaker
Is the gem sounds tr-150 build with an internal amp?
No, these are passive speakers that need to be driven by a power amplifier
Posted on Aug 01, 2013
If all speakers except some of the super tweeters in my gem sound tr-150 cabinet aren't working, could it be the crossover network that they appear to be all wired to, is no good, or do you think all...
Did you actually mean "all speakers... AREN'T working" except some tweeters? Crossovers don't protect the woofers. If crossover die all speakers they protect go silent due to loss of signal. Excess volume or distortion kills speakers and not always linearly.
If you said it wrong and some tweeters work, I'd suspect the latter above...
You (or we) could guess or you could take out one tweeter at a time and swap it with a (presumed) working one or just emasure it for dead short or open with an ohmmeter. If the tweeters check out and work elsewhere the problem would likely be within the cabinet.
Sep 08, 2011 | Gem Sound TR-150 Speaker
You guys was helpful last time so I thought I would ask more!!!! DJ equipment Gem Sound amp EVA-3955 at 8ohms 2x250w blew 2 Tr-150 15'' 8ohms rated at 600w blew. what replacement should I go with same size...
Typically large speakers like that blow up because you are trying to put frequencies into them that they can not reproduce. How are these units connected? Is the crossover frequency correct for these 15" speakers? Putting signals higher than about 1000Hz will start to heat them up. too much heat = blow-up.
Also, I'm not familiar with the tr-150s. Is the 600W rating a PEAK rating or continuous?
Dan
Jan 06, 2010 | Audio Players & Recorders
I Have a Gem Sound EVA3955 amp an TR-150 subs sub stop wroking
Yes and Yes. If bypassing that noise filter, has no effect your subs could have blown.
Jan 05, 2010 | Car Audio & Video
I have Exa 3955 amp and TR-150 subs mid range and tweeter works subwoofers stop playing both
Open the sub box, and check to make sure the sub wires didn't become disconnected. You should need only a screwdriver.
Jan 05, 2010 | Gem Sound Car Audio & Video
Gem sound exa 3950 amp
Hi...
If it's a straight-up power switch then it will need to be replaced if it works off a relay then the relay is gone.
website
http://www.gemsound.com/contact.html#
Mar 24, 2009 | Gem Sound GemSound PA-585 2-Channel...
Sound
I plugged mine to the red and white aux ports on back of my sterio.
Dec 21, 2008 | Gem Sound CDM-150 Mixer
CDM 150 IPOD question
OK all you need is a 1/8 th inch stereo jack that goes out into two RCA cables RED and White (you can get this conector at any radio shack) now plug the red and white wires into the back of your gem sound unit AUX or TAPE..plug in your mp3 through headphone jack into 1/8 in plug....now turn on set switch to AUX OR TAPE DEPENDING on the one you plug into ..now play your mp3...make sure volume is up!
This should fix YA!
Dec 12, 2008 | Gem Sound CDM-150 Mixer
Gem Sound clipping problem
First of all the EXA-3940 is rated at 350watts per channel in to 8 ohms. The 1400 watts is bridged into a 4 ohm load. Second, the speakers can handle 1000Wats peak with an average of 600 continuous (i'm guessing). That tells me that the amp is underpowered for the speakers. The sensitivity of the amp is such that the mixer is overdriving the input stage. That is what is causing the clipping. If you are looking for more volume, you are probably better off purchasing another amp and running them in bridge mode, 1 per speaker cab. Be careful though, not to overdrive the speaker cabinets either.
Dan
Sep 21, 2008 | Gem Sound GemSound PA-585 2-Channel...
Gem Sound CDM-150 Dual cd player
This is what I did to get a copy, I went on different store sites that sold this product and I found that some will advertise the product, it's functions and its instruction manual. When you find it just copy and paste the page.
JLofton(2Housepeople)
May 21, 2008 | Gem Sound CDM-150 Mixer
60 people viewed this question
Top Gem Sound Audio Players & Recorders Experts
 Grubhead
Grubhead
sean tan
Level 1 Expert
Are you a Gem Sound Audio Player and Recorder Expert? Answer questions, earn points and help others
