Question about Dell 0JM629 Inspiron 1520 Keyboard
Keyboard on my dell 1520 is working fine but for the right cursor key i thought it might be a faulty keyboard so i replaced it with a new one but i still have the same problem, can you shed any light on my problem
4 Suggested Answers
  • 46 Answers
SOURCE: Keys on right hand side of keyboard do not work (Dell Quiet Key)
go to control panel & check for keyboard layout settings also connect another keyboard & check if it is a hardware problem
Posted on Feb 24, 2009
sasha_groves
  • 68 Answers
SOURCE: Touchpad and cursor keys quit working
I used to get this problem. It is VERY annoying as you must know. try pushing the windows icon button in the top right corner of your keyboard(thats where it is on my keyboard)then use your arrow keys to scroll up to control panel, select mouse by using arrow keys and then use the tab and arrow keys to open the mouse keypad pagetab and push enable and enter key to turn it on.
IF WHEN YOU DO THAT AND your in the touchpad properties but there is no 'enable' and it says no hardware detected, then go into the same mouse window from the control panel and go to the hardware tab and either try to update driver or use the trouble shoot button.
Hope this helped =]
Posted on May 27, 2009
deepakkumaar
  • 167 Answers
SOURCE: my laptop keys are not
Once clean your Laptop with a smooth cloth and try to clean the edges of your Laptop keyboard and see that all you setting are normal and default in your control panel settings and this above not work just reassemble the system i mean remove all the components and Re fit then you can solve the problem
Posted on Aug 15, 2010
Dell Vostro with XP - cursor is running rogue and endlessly going backward.
This "can" be malware, but is most likely your pointer device going wonky. First unplug the mouse, trackball, or whatever it is you are using for a mouse. If you are still using an old PS2 connection (round plug), consider getting a USB mouse to replace it.
Plug your mouse back in and see if it solves the problem.
Try a new mouse.
If it's not the mouse (you just said the cursor is moving) it could be that the left arrow on your keyboard is stuck. In that case, rake your keyboard, tap ******* the arrow keys, turn over the keyboard and shake out any large Cheeto crumbs, use compressed air (if possible) to blow the dust out.
Unplug your keyboard from the computer and plug it back in. If you are still using the old PS2 keyboard (round plug), consider getting a USB keyboard to replace it. *** warning
*** warning, do NOT throw out the old PS2 plug keyboard if you replace it. You may need it to get into the BIOS some time in the future if the electronics don't recognize a USB keyboard on boot.
Feb 07, 2018 | Dell Vostro 1520 Notebook
Left shift key not working
Hi Marcy,
Check that the key depresses all the way (same amount as other keys next to it). If so, then the most likely problem is that the keyboard has failed. You can have the keyboard replaced fairly easily.
Keyboard for the Dell Vostro 1520 costs $20 or less depending on where you buy. You can view YouTube videos on how to replace the keyboard or have someone professionally replace it for you.
Keyboard replacement on YouTube
Aug 06, 2012 | Dell Vostro 1520 Laptop
I have a Dell Vostro 1520 and suddenly none of the keys will respond - I have tied to access Sticky key settings by continually pressing the shift key - i obtained it once but cannot get it again - any...
It could be the plug is not inserted correctly, the keyboard is bad switch out to see, check device manager to see if computer thinks keyboard is installed ok. If not delete it and reboot.
Jun 16, 2011 | Dell Vostro 1520 PC Notebook
Dell Inspiron 1545 laptop keyboard cursor jumps to mouse cursor position while typing
Go to http://support.euro.dell.com/support/index.aspx?c=uk&cs=ukdhs1&l=en&s=dhs
Click the drivers and downloads section.
Enter your service tag number and procced to the download section.
Click Input Device Driver and dowload the alps touchpad exe file. Run this and your problems will be solved.
Oct 15, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
Problem with text cursor
Check the issue in safe mode. If the issue not present in safe mode,Try calibrating the touch pad.Also try creating new admin account and check the issue.
Aug 18, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
Moisture in keyboard of Dell Inspiron 1520
Use alchohol to clean the key board so that it will absorb the excess moisture. If this is constantly happening that your key board becomes moist, icky wet ...usually means ur cooling fan is not working properly...could mean getting a new one.....suggest cleaning the fan to get out the dust and grime that builds up with the heat and dust.
Jul 22, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
Hope this helped =]
May 27, 2009 | Dell F3534 Touchpad
My s key on dell laptop is sticking , hard to press model 1525
If the system is still under warranty, contact Dell technical support for a replacement keyboard. If it is not, you can buy a new keyboard here:
http://cgi.ebay.com/NEW-Keyboard-for-Dell-Inspiron-1420-1520-1521-1525-1526_W0QQitemZ330252862696QQihZ014QQcategoryZ31568QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Jul 16, 2008 | Computers & Internet
Dell 0JM629  Inspiron 1520 Keyboard  Logo
Alun Cox
