Question about Electrolux Centralux Vacuum
I have a model 1561 electrolux central vac..can i use a hose and accessories from a model 15448 model electrolux central vac to compliment my central vac unit
  • 694 Answers
If the hose fits into the inlets, then there should be no problem.
Posted on Oct 04, 2010
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
I have an electrolux central vacuum in my house. My central vac hose has something stuck in it, I think, maybe a sock. I tried to put a long dryer wand down it but the hose is just too long. Does this need...
The best way to clear an obstruction is to blow it out by attaching the wall end to the exhaust of a shop vacuum, or using an air compressor.
You can try holding the wand end of the hose directly to the CV in port and turning the machine on. This provides essentially the same action as the previous method.
If neither of these work, try a combination of the two. Or using a shop vac, hold the wall end to the exhaust of the vacuum and the wand end to the in port of the shop vac. Turn shop vac on and the obstruction should come out.
Borrow a good strong shop vacuum if you need to.
If these methods fail, take it to an authorized Aerus Electrolux store and have the service tech try to clear it. Care must always be taken when trying to clear an obstuction with a long object, especially if it's pointed. I've seen many hoses that have shorted out and even caught fire due to the wiring accidentally being "nicked".
Jan 03, 2011 | Electrolux Central Vacuum
Central vac system is 18 years old. Recently started to shut down during vacuuming. Motor may be over heating. Electrolux has been out and is pushing a new system but not sure if it is necessary.
The motor can be replaced for a lot less than the cost of a new machine. A new motor comes with a one year warranty if installed by the service tech. A new CV unit alone may be over three times as much, but does have a five year warranty.
At 18 years, there are other things that could be getting worn out as well. If you happen to need to replace them over the next year or two, then you would have been better off getting a new machine. Just the motor and hose can be over $600. Add the power module, power nozzle or parts, and wands, and the costs can end up being over $1000. So take a look at the hose and accessories. If they show a lot of wear and tear, then it might be better to replace the whole thing. A new machine carries a five year warranty, which also covers accessories.
Also, have you notice a loss of suction? This usually results from a worn out, leaky hose, and with a 30 foot hose can result in a tremendous loss of suction.
Just take all things into consideration.
Personally, I'd recommend a new canister vacuum. Depending on the model, they come with a five to twenty year warranty, with five on the accessories from the hose down.
Dec 01, 2010 | Electrolux Cs 3000 Central System Vacuum
Electrolux 1590 not turning on
TRY JUMPING THE CENTRAL VAC INLET WIRES AT WALL! IF COMES ON SOMETHING IS MISSING ON HOSE TO WALL CONNECTION. MOST HAVE A METAL RING TO ACTIVATE THE INLET DOOR WHEN HOSE IS CONNECTED.
Dec 12, 2009 | Electrolux Vacuums
My electrolux central vac clicks when I try to start but won't tu
It sounds like you have a bad motor. Motors can be replaced easily. You will need to know the model number. There are several companies online that sell replacement motors.
Aug 27, 2009 | Electrolux Centralux Vacuum
Electrolux Central Vac- One hose works well, one does not
if its an older hose it might be crunching up when the vacuum is running that couses a loss is airflor due to high resistance. if this is the case the hose should be replaced.
Jun 21, 2009 | Electrolux Central Vacuum
Metal hanger stuck in central vac hose
there should be a pin push it in then pull out power head then try to pull out hanger
Feb 08, 2009 | Electrolux Central Vacuum
I need a new hose for my Electrolux central vac
Do you need a new powerhead too or only the hose? If you need a new powerhead than I would recommend looking at the Imperium Pro Elite Attachment set. It is an excellent quality powerhead and hose. If you only need a new hose than you will need to contact the Aerus because they will be probably be the only company who can sell you a hose that wil be compatible with your powerhead. Their website is http://www.aerusonline.com/products/
Jan 21, 2009 | Electrolux Central Vacuum
Electrolux Centralux Vacuum Logo
268 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
