Question about Bissell 8920 ProHeat 2XTM Upright Vacuum
Did the brush supposes spin when i clean it? - Bissell 8920 ProHeat 2XTM Upright Vacuum
  • 694 Answers
It shouldn't spin freely. Check the belt.
Posted on Oct 04, 2010
Hi i have a hoover F5853 when the brushes in contact with the carpet they quit spinning but it is on and lift the front up they start spinning but as soon and i put it back down they quit please help
Belt around brush roller is worn, it spins freely when there is no pressure on it. But put it on the floor, the belt won't turn the brushes. I suggest taking unit to vac repair shop for new belt installation
Dec 05, 2014 | Hoover Vacuums
Is the brush on my hoover steam cleaner suppose to spin
I think it does other wise how is it suppose to clean. If it's not sounds like a broken belt.
Jun 26, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell 3750 bottom brush will not spin belt is fine and lift off works great
Hey Jessica! Please contact us for assistance regarding your vacuum.
Here's a quick link to assist you:
http://www.bissell.com/contact-us/?cid=ccsocial
Mar 04, 2013 | Bissell 3750 Lift Off Bagless Upright...
Beater does not work.
Not knowing what type of vacuum you have does not make it easy. However, usually caused by a broken belt or the fact that the beater brush is bound up by debris either being on the beater or having accumulated at the ends of the beater where the brush is supposed to spin on the end plates. After checking the belt I would remove the beater brush, clean it very good and put some WD40 on the ends of the axle of the beater brush and make sure it spins freely on the holding plates.
Sep 08, 2010 | Vacuums
The vacuum was working fine then suddenly the main brissels that spin to collect the dirt stopped spinning, the vacuum still has suction but barely picks anything up because the brissels are not spinning
Best thing to do is remove the spinning brush and clean all debris from the brush and most importantly from the ends of the brush. The ends of the brush usually have two holders (square?) that hold the brush in place on the vacuum. The brush is supposed to spin in these holders. If it does not, provided the belt is okay, the location where the brush contacts these holders need to be cleaned and lubricated with some WD40 or some 3 In 1 oil. Be sure the belt is in proper running condition as well.
Sep 05, 2010 | Bissell Cleanview Helix Vacuum
Belt burned up (first time); installed new belt but that starts to burn also; approx. 2 years old
Sounds like the brush that the belt is supposed to turn is bound up tight. Need to remove the brush and clean all debris from it. Where you can get at the center rod for the brush, the rod that the brush spins around, clean the ends and add some WD40, being sure not to get it on the belt. This should remedy the problem of the belts burning as long as the belt is put on correctly.
Aug 27, 2010 | Panasonic Vacuums
Cleaning Challenge to Resolve Error Msg. 2 on my 560 iRoomba
That bearing usually snaps on, and is actually supposed to be a bushing. If it is spinning freely, it shouldn't be removed.
Mar 15, 2010 | iRobot Roomba 560 Robotic Vacuum
Is the brush on the bottom suppose to automatically spin when powered on?
If its upright the brush will not turn.It only turns when in pushing position.
Jul 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Irobot roomba 570 brush not spinning
Unscrew and remove the side brush. There is probably a wad of hair and dirt underneath it that's keeping it from spinning. When it's clean, *snap* the brush back on, then screw it into place. If it still doesn't turn, you'll need a new module. Call support: 877-855-8593. Good luck.
Jul 02, 2009 | iRobot Roomba 570 Robotic Vacuum
Brushes won't spin
The brushes are turned by belt and/or motor.
Mar 09, 2009 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Bissell 8920 ProHeat 2XTM Upright Vacuum Logo
22 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
