Question about Neovo F-417 17" LCD Monitor
Neovo F-417 monitor keeps switching off and takes several minutes to be able to switch it back on again
    Sergeant:
    Champion:
  • 293 Answers
The power supply of your monitor have problem.Leak capacitor at ur power supply need for replacement
Posted on Oct 05, 2010
My Neovo F-417 started to get lines across the screen then the images fragmented - 10 minutes & it lost power totally.
Chris,
Try unplugging the monitor from any video cables. Only have the power cable plugged into and then turn it on. You should see a message that indicates there is no video source. If you do not see this message then the monitor has failed, and you'll need to call it in on it's warranty. (If it is still under warranty.) To call neovo - the number is 866-333-3686.
If it is out of warranty - it's going to be cheaper to buy a new monitor.
If the video message that there is no signal does display, then try plugging the monitor in with a different video cable and see if that has any results. If not, try plugging the monitor into a different computer. If it works on a different computer, you may have a bad video port on the computer you are plugging the monitor into.
Hope that information helps!
Nov 21, 2011 | Neovo F-417 17" LCD Monitor
Why does moniter keep saying check video cable when turned on it is connected right
It is quite common for new flat screen monitors to report this as computer boots up. If it comes back on each time and continues then just ignore it. PC's switch the video output on and off as they power up. This is normal. New monitors are just impatient. Ian.
Sep 18, 2011 | Neovo F-417 17" LCD Monitor
Hi, i need to know how to change the backlight on a neovo f-417 moniter. please help.
Though this may be an easy or not easy task I would suggest you take your monitor in to have it serviced. If you the unit is still under warranty and you take it apart your warranty could be voided If applicable. On the other hand if you do decide to do it yourself be VERY CAREFUL as these monitors can easily be damaged.
Jul 13, 2011 | Neovo F-417 17" LCD Monitor
F-417 Neovo monitor only works in safe mode. Can this be fixed?
Can you please clarify the problem? It works if you start the computer in safe mode but not in normal mode? Do you get the message like 'out off range", "format not supported"?
Mar 18, 2011 | Neovo F-417 17" LCD Monitor
Please ? i need shematic diagram for monitor NEOVO F - 417
jais un probleme avec mon monitor lcd nuevo s17 ,il s'allume et l'écran ne s'affiche pas c'est quoi la solution a se probléme
May 29, 2010 | Neovo F-417 17" LCD Monitor
My Neovo f-417 LCD Monitor is switching off after 3-4 seconds. Green lamp is still blinking but there is no ligts and picture on screen. Only black screen
This means there is a hardware failure in the monitor that could be either blown CAPs or a shorted out inverter. It is difficult and dangerous to replace both of those(involving soldering and desoldering) if you don't know how as LCD's are made of a hazardous material. I would try new cables and on a different computer as a last resort and if that doesnt work then your monitor is trashed. If it works on another computer then the issue is not with your monitor. Good luck!
Sep 23, 2009 | Neovo F-417 17" LCD Monitor
Neovo F-417 17" LCD Monitor Logo
408 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
