Question about Rival Kitchen Appliances - Others
This has been a great appliance. The pan and glass cover clean up quickly in soap & water. This appliance electrical power unit has never been in or near water. It has worked flawlessly. Suddenly it stopped working. No on light or heat. What to do?
  • 1,711 Answers
The temperature control dial - thermostat or heating element, need to be replaced. You need to check both.
Since you don't have the power indication light then it might be first the thermostat or a wire attached to it has been burned out and there is not any contact. Replace wires or replace thermostat.
If they are ok then check heating element if there is an open in continuity test then replace.
Posted on Oct 04, 2010
Dishwasher is rinsing and soap coming out but not washing what could be the problem
Hello;
My name is Peter. I am a retired field service appliance technician.
I do not know what model you have so I can only be general.
There are several reasons why your dish washer is not cleaning so I am going to give you two basics to start.
1.) If you have a filter, remove it and gently clean with soapy water.
2.) If you have a drain cover in the back, remove the two screws. Wearing gloves (There may be broken glass in the drain) reach down and remove any blockage. Siphon the water out. There is a metal plate at the bottom, this may be stuck open. You may be draining the soap and water out as soon as you fill.
3.) Your washer blades may be plugged up. Put 1/2 cup of white distilled vinegar in the bottom of your dishwasher. Run it on Hot & Heavy cycle.
There could other problems, but I need your model number
Dec 09, 2014 | Dishwashers
Cleaning glass lid for SS frying pan. Surfaces are clean but svere spotting still exists is this doubkle wall glass???
Use Dawn dish soap, rinse in as hot a water as you can handle and dry immediately with a cotton or linen towel. Should work.
Mar 13, 2014 | Home
How do you clean a wok without ruining it?
After use;
1. Rinse your wok in warm soapy water and remove any food from the inside surface.
2. If you need to clean the wok more thoroughly you can do it in hot water but don't use any soap or chemicals.
3. Dry the wok with a towel
4. A properly seasoned wok won't give off any black smudges. If yours does, it may still be dirty or just need to be seasoned again.
Feb 18, 2013 | Home
We have a kitchenaid superba oven glas top and i like to clean it but i do not know how can you help me e-mail me at
Purchase a cleaning spray. Easy-Off Glass Cleaner, Windex or Drackett Glass Cleaner are all available from local department or grocery stores. You could also use dishwashing soap. Any non-abrasive, bacteria or grease removal product would clean glass cooktops.
Spray the whole cooktop area. Allow the cleaner to sit for about 2 minutes. If you have stuck-on food, spray only that portion of the cooktop. Let the liquid sit for approximately 5 to 10 minutes.
Use hot water. Soak your sponge and wring it out. Wipe down the glass cooktop. Carefully scrub the stuck-on food. Run the sponge over the spot area at least 20 times to remove the food. Wring out the sponge and rub the remaining portion of the glass countertop
Use a terry cloth rag to wipe down the cooktop. This will remove excess water and soap.
if you have any further questions please message me back and please remember when our chat is concluded to rank how this opinion has helped in your appliance situation Thanks again Rick
Jan 01, 2011 | KitchenAid KEBS177 Electric Single Oven
2H at the start with the cycles running into hours now
the only possible reason it to take 2 1/2 hrs for a cyc is if you selected pots/pans and sani and or heated water... possible cures for this is use only power soap also jet-dri if unsure if dispenser is working on buy to solid hanging type then turn on hot water at sink b4 you start a cyc then if you have a watersoftner do not put more than 2 tsp of soap per opening on the soap dispenser then place a clear jar with no cloudyness, do not prewash the dishes b4 washing in unit only scrape and do not select the heated wash using liquid soap is able to be broken down in cold water so if this cleans your dishes and you inspect the clear jar you placed in the unit and not cloudy... this is the way youll have to use this unit if the cloudyness is able to come off the best way is to get citric acid available at most pharmacys wear glove and wash by hand if comes out saveable if not other are destroyed then as a last remecomended use product lemme fresh for dishwasher this is not a soap but assist in keeping a sheen on you siliverware and glassed
Aug 19, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Frigidaire FRT18IL6D
Hi thanks for your question. to unclog. pull fridge away from the wall. remove back cover , clean all coils. let fridge thaw for at least 24 hrs. get small plastic hose to push up the drain tube from the back. blow up yhr drain tube to clear the tube. thanks the appliance doc. please rte my answer, thanks.
Oct 12, 2008 | Frigidaire FRT18B4A Top Freezer...
Subject is Bosch dishwasher SHU6800. There is a soap residue left on dishes. Residue is not visible. Using two glasses taken from a recently completed wash cycle I rinsed one under tap water and then...
WHAT IS WRONG WITH YOUR DISHWASHER?
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Aug 17, 2008 | Dishwashers
HElp Dishes not coming clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchen Appliances - Others Logo
130 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ed Mac
Henry  Thomas
Henry Thomas
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
