Question about Canon PowerShot A550 Digital Camera
I bought a new battary door for my A550. How to replace the battary door? which screws to remove? Is there any scheme?
    Novelist:
  • 178 Answers
While the battery door looks simple the mechanism is assembled in a way to make it a tight fit. Make sure you have all the precise correct tools. Using an incorrect tool might make this worse by not allowing you to remove the current parts. If you are unable to obtain you might want to contact Teleplan Camera Repair and see if they will work with you. http://www.teleplancamerarepair.com/
Posted on Oct 04, 2010
How to remove flat battery from canon power shot A550
Look at the little door labeled CR1220 in this picture. Pry it open with your fingernail, and take the battery down to your local drugstore to buy a replacement (should be around $3).. Note that W-mart for some reason is expensive for the common CR1220 battery compared to retail drug stores.
Jul 27, 2011 | Canon PowerShot A550 Digital Camera
Low battery all the time
this is not a good signal. you can make this prove. clean the internal camera contact with a specific contact spray and one cotton fioc
ore you can use normal denaturated alcohol. this is one possibilty. if you dont have any betterment. its probably that the camera have a eletronic defekt. this is not so uncommon with old camera. the camera have internal fuse the works not good and gives this problem. motherboard defekt. good luck i hope for you that is only a dirty contact faulty.
paolo
Jun 01, 2010 | Canon PowerShot A550 Digital Camera
A550 date/time problem
Open up your battery door, and you'll notice another tiny door labeled "CR1220". Pry open that door with your fingernails, and you'll find a little button watch battery that keeps the time settings for your camera. It's time for a new battery. Take that little battery down to your local drug store (Walgreens or Rite-Aid). Should only cost about $4. Note that Walmart is more expensive for these type of batteries, and drug stores are usually cheaper (I know, it's hard to believe).
Feb 18, 2010 | Canon PowerShot A550 Digital Camera
How do i replace pass. outside mirror on a 04' nissan maxima
First you need to get you a new mirror, then once you have it remove the door pannel, so you can get access to the screws located behing the little tweeter located on the inner side of the mirror. To remove the door pannel you need a philip head screw driver with magnet preferable, or a socket size 10mm. remove the little plastic square on the door opener of the inside, plus remove very carefuly to not brake the clips gray shiny of the hand rest side and remove the two screws of the very in. once you remove the those two screws, insert something flat in behind the pannel to be able to lift it, try to pull out kind of gentle try not to lose the white push pins of the back of the pannel. now you have the view and access to the screws that hold the mirror and don't forget sometimes the new does not include the wheater strip going inside the mirror to prevent the water of going in, Just reuse it and screw it back and just do everything vise-verse. Good luck!!!
Mar 29, 2009 | 2004 Nissan Maxima
How do i change the door seal?
You'll have to find the screws that hold the door skins together. Take them out, replace the seal & reverse the order.
Feb 13, 2009 | Select Brands Washing Machines
Canon Powershot A550 flash will not work it just blinks on & off?
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD750 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
Dec 01, 2008 | Canon PowerShot A550 Digital Camera
A550 powershot flash not working
we all need new flashes it costs 90 bucks to replace it
Mar 06, 2008 | Canon PowerShot A550 Digital Camera
I dont know the Maytag model - but is has a CERAN top
There are a few screws located under the front edge of the top. You will need to open the oven door to see them. Remove these screws and the top should lift up. Make sure you unplug the range or turn off the main breaker BEFORE servicing. There are still live voltages present with the range turned off. There are a couple of screws holding the element in place, as well as some wires. Make sure you write down how the wires were connected to assist you in reconnecting them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of on the old element. Last of all, make sure you handle the new element carefully. Care must be used not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. Good luck and I hope this helps.
Sep 07, 2007 | Maytag MER5775Q Electric Kitchen Range
Canon PowerShot A550 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
