Question about Sony Handycam DCR-PC9 Mini Digital Camcorder
I have a Sony Handycam DCR PC9 mini camcorder and it will no longer recognize the battery. I have replaced the battery and it still wouldn't recognize the battery. The screen flashes a picture of a battery as thought it's saying no battery installed. I have since tried 4 batteries, all new, my camcorder will not recognize any of them. Will appreciate any suggestions.
  • Nitin VishwakarMa Oct 04, 2010
    is your camera is working fine with your ac adaptor
SOURCE: Sony Handycam DCR-PC109E User manual
I moved every moveable object on the handycam to no avail and then I wiped the screen to clean it and got the menu. It is a touch screen cam. Thanks antway.Ian
Posted on Feb 16, 2008
SOURCE: sony handycam dcr-trv19e mini
Thank for that qestion,
At this point, if you are a lay-man or person you need to eject the camcorder and aloud it open and put under sun light for an hour. If its do the same, take it to a technicain.
but if you are a technicain, dismantle the camcorder and put the machinusm under hot tempreture for 20minute. then mount it back and your camcorder will be fine.
I have done this time and again and it has never fail me.
I hope you will smile.
Posted on Jun 11, 2008
welcomejee
  • 10594 Answers
SOURCE: I have a Sony Handycam DCR-TRV22E Mini DV Digital camera and cannot get my PC to recognise it.
Go to camera menu and enable USB Stream, problem will be solved and PC will recognise your camera.
Posted on Jun 21, 2008
welcomejee
  • 10594 Answers
SOURCE: my sony dcr-dvd105 handycam camcorder all of a sudden shows only
There is 2 possibilities, either aperture of camera jammed and doesn't open or CCD Imager got defective in your Sony DCR-DVD105 camcorder.
Let me know if you have little experience of camera repair to guide you further.
Posted on Nov 29, 2008
SOURCE: sony handycam dcr-trv19 mini dv
Because of the fact that Microsoft thinks they're so smart and released Windows Vista as their newest piece of ****, this camera will not work with Vista. The drivers for Windows Vista are non-existent. I went to the site for Sony and could only find XP drivers and 98 and 2000. They do not make them for Vista. And of course Vista should have most common drivers preinstalled, yet they don't have this one. I haven't found a way around it yet. I tried to get the drivers for Windows XP and install them. No good! It cannot be used on "this current operating system." Good luck. Hope somebody else finds an answer.
Posted on Dec 25, 2008
Sony dcr-pc9 ejects tape when trying to load....not a claening issue..common symptom on this model
Try this:
1. Turn off the Handycam
2. Remove the battery from the Handycam.
3. Remove the AC Power Adapter from the Handycam.
4. Move the Handycam power switch to the ON position.
Note: Leave the switch in the ON position for at least 15 seconds.
5. Move the Handycam power switch to the OFF position.
6. Connect the AC Power Adapter to the Handycam.
7. Turn on the Handycam.
Apr 05, 2011 | Sony Handycam DCR-PC9 Mini Digital...
Sony Digital Handycam error c 31.21.have tried all the posted solutions.....no luck!!! should i try brand new tape? thanks
I've a PC9 (close cousin of 101) when it first came out and have never encountered a C31 before. You've probably try putting in a new tape by now. What's the verdict?
May 20, 2010 | Sony Handycam DCR-PC101E Mini DV Digital...
How do I delete content off of a memory stick?
Go to the camera menu look for set up then look for memory stick choice to formate the whole memory or delete contents one by one manualy....Easy as one, two. three.....
Good luck............
Nov 02, 2009 | Sony Handycam DCR-PC9 Mini Digital...
Battery is not charged - Sony DCR-TRV 25E
I SUGGEST YOU THAT YOU SHOULD CONTACT SONY,AND ASK THEM TO CHECK UP YOUR CAMCORDER.I THINK THERE IS SOMETHING WRONG WITH THE CHARGE CIRCUIT.
May 24, 2009 | Sony Handycam DCR-TRV25E Mini DV Digital...
Error code! C:2100 what does that mean
Many have found smacking it fixed the problem. I myself have been doing this nonsense for years. until now ...No need to smack your Sony :) A more permanent and simple solution is to clean the dew sensor with a q-tip and alcohol. Kid you not, I've been "hitting" and abusing my sony in public for over 2 years ... until i found this simple fix.
Apr 27, 2009 | Sony Handycam DCR-PC9 Mini Digital...
Moisture detector flashing - won't accept tape
You need to clean the dew sensor with a q-tip & alcohol. If yours is like mine (PC9) been around for over 9 years so the sensor has been oxidized to a point where its no longer reliable. You can have it replaced (part is under $10) but labor is well over $200 from Sony. I wont sink that kind of money into an old DV camcorder ...
Mar 29, 2009 | Sony Handycam DCR-PC101E Mini DV Digital...
Downloading images
Make sure you have a DV cable also know as a firewire cable. You will need some software to capture the video from your camera to your hard drive. Pinnacle Studio is an inexpensive system for capturing, editing, and producting videos to DVD.
Make sure you have a firewire port in the back of your computer.
Jul 20, 2008 | Sony Handycam DCR-PC9 Mini Digital...
Download moving images to computer for duplication to dvd.
You will need to have a firewire cable at the very least. Then if you have a more Windows XP (or higher) PC equipped with an ieee1394 hardware or an apple computer ... you're all set to capture video from PC9 to other format like youtube or DVD.
May 12, 2008 | Sony Handycam DCR-PC9 Mini Digital...
Sony camcorder DCR-PC9 NTSC
Hi FixYa.
My cam corder is model number DCR-PC9 not DCR-TRV525
dileep007 tried to help me was not successful
I have always used DVM60 casset
Will appreciate help to solve the problem.
Sincerely
Mark Kaufman
Feb 19, 2008 | Sony Handycam DCR-TRV525 Digital Camcorder
Sony Handycam DCR-PC9 Mini Digital Camcorder Logo
21 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
