Question about Maytag Neptune Washer
Noisy bearing while spinning - Maytag Neptune Washer
    President:
  • 670 Answers
The seal in the drum has failed allowing water to leak into the bearings causing them to rust. Once the bearings are no longer round, the bearing noise will get louder. To replace, the washer needs to be taken apart and the drum needs to be removed in order to replace the bearings. Can be a difficult and expensive repair. Get a few estimates before deciding whether it is worth reparing. Sorry.
Posted on Oct 04, 2010
What can cause noisy spin on wd960 hotpoint ?
bad bearings, seal leak let water in bearings
Tub seal leaking letting water get to tub bearings need shaft and bearings replaced. takes special tools
Aug 31, 2014 | Hotpoint Washing Machines
Very noisy when spinning - suspect bearing problem. Would appreciate advice on bearing replacement. Model no. WF 240
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 30, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Drum bearing noisy on spin
Remove the drum drive belt, and spin the drum by hand.
If it is noisy, or feels rough, then the main drum bearings have failed.
This a major repair.
Hope this helps.
Dec 15, 2009 | Candy Washing Machines
Aquarius 1100 wm63 very noisy spinning
Remove rear cover of washer.
Remove drive belt.
From inside the drum, spin the drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
If no noise, then possibly motor bearings noisy.
Hope this helps Thankyou.
Nov 27, 2009 | Hotpoint Washing Machines
Noise when spinning
Remove drive belt and spin drum by hand, if it is noisy, or feels rough, then the main bearings have failed, if no noise, then check for noisy motor bearings.
Please rate my solution.
Thanks.
Jul 18, 2009 | Hotpoint Ultima WF860 Front Load Washer
Whirlpool wfs1285aw noisy spin cycle
Hi..
If you washer is noisy,
  • Check that the water supply valves are turned on
  • Inspect the filter screen
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve
  • Test the motor
General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Good luck !!!
Regards
PCmania
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG direct drive washing machine is getting increasingly noisy when at the spin stage
generally when a machine gets noisy in spin cycle it is due to bearings being worn open the door with the machine empty and try lifting the the drum upwards if it moves then it will be the bearings
Jul 12, 2008 | Washing Machines
Noisy spin cycle
The spin bearing is the culprit. Water works down through the tub seal onto the bearing.
Jan 15, 2008 | Maytag MAV8557 Top Load Washer
Wm noisy
drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
Sep 25, 2007 | LG WD-16110FD Front Load Washer
Washing Machines Logo
171 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
