Question about Dyson DC14 All floors Bagless Upright Cyclonic Vacuum
The machine runs for brief periods, then shuts itself off. If it is allowed to sit for several minutes, it runs again, then shuts itself off.
    Problem Solver:
  • 9 Answers
The motor is heating up to much and the cut out switch is kicking in. You need to check the the motor filter, and worse case you may need to new motor..
Posted on Oct 04, 2010
Periodically my Dyson DC07 stops operating, and then will resume operating after about a 10 minute wait period. Is there a thermal switch or "cutout" if the motor is overheating?
Hi there, it's Jack at Dyson.
Like most Dyson vacuums, DC07 is equipped with a thermostat which shuts the machine down for protection if it starts to overheat. This will often be due to a blockage, and the pre-filter may also be overdue for a wash.
The machine will reset automatically after it's been allowed to cool down, but to prevent this from happening again there are a few simple check you can try: http://www.dyson.co.uk/support/dc07/dc07-standard/my-machine-is-not-working/machine-won-t-switch-on-or-cuts-out/my-machine-cut-out-whilst-i-was-using-it/how-to-wash-filters/wand-suction
We recommend washing the filter at least once every 3-6 months, using cold water without detergent. Allow the filter to dry completely before replacing it - this may take at least 12 hours.
Removing any blockages and washing the filter thoroughly should resolve the issue. However, if your machine continues to shut off after you've tried both of these steps please get in touch with us directly so we can talk you through some additional troubleshooting checks. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 10, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
S7000 Just shuts off...
It's shutting down due to overheating to protect the motor ( and to prevent a fire! ). Running it and feeling around the motor to see if it's gotten hot would be the first thing I'd check. If the vacuum is new and giving you these problems, I'd return it to the store you bought it from and see what they'll do about it..there may have been a recall you aren't aware of.
Jan 13, 2014 | Miele S7210 Bagged Upright Vacuum
After using the vacuum for a while it would stop running. After sitting several hours it would run again. Now it won't run at all. It was just a couple of months old and I haven't been able to use it...
If you would take the machine all apart in little pieces, you should find it is clogged with dirt or hair or whatever you have been vacuuming up.
Different brands of machines will last longer or shorter periods of time because of plugging up.
Most all of them can be cleaned, but some will just clog again quickly.
I personally use "Consumer's Report" to find good machines.
God bless your efforts.
Dec 07, 2017 | Dirt Devil M130000 ''i'' Dual Cyclonic...
My Hoover runs for a few minutes and shuts off.
It's possible the thermal reset is defective. It shuts the motor off if it gets hot. Remove the bag door and take the bag off, remove both filters and then turn the vacuum on, just leave it sit there with the motor running. This eliminates the bag or filters causing any airflow resistance. If it still shuts off after a few minutes it's likely the thermal reset is bad. Some vacuums have an external thermal reset button which can be replaced if necessary but on your model it is built into the motor and you must replace the motor. If the motor runs fine put the bag and the filter under the bag back in - (make sure the filter is clean and not restricting airflow) put the bag cover on then turn it on again. If it overheats and shuts off then you may have a clog on there somewhere restricting the airflow. If so check the power nozzle area, the hose coming from the power nozzle, the extension hose and wands for clogs or restrictions.
Sep 22, 2017 | Hoover U6426-900 Bagged Upright Vacuum
After using the unit for a few minutes it cuts off.
The electric motor inside your Dyson has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, next time it is switched on it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are available on eBay for about £25, however replacing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Apr 17, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
We have a dyson root cyclone and it shuts off after a about 5 minutes of running. Then after about 10 minutes it will run again.
Your description is typical of a machine that's overheating. This is almost always caused by a blockage, as restricted airflow can't keep the motor cool and the automatic cut-out shuts the machine off. It re-sets itself when it's cooled a bit. Check your operator manual for how to clear blockages, and also check that your filters are clean.
Nov 28, 2009 | Vacuums
Cleaning solution will not dispense
After sitting for a period of time, some of the solution may have dried in the inner walls of the feed tube from the solution tank. What I would suggest is to empty the solution tank and then fill it with hot tap water, put it back on the Floormate, and hold the solution "feed lever" on until it starts dripping water. The hot water will hopefully disolve the dried solution and allow it to flow again.
I hope this helps! :)
Sep 22, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
CLEANER SWITCHES ITSELF OFF AFTER A FEW MINUTES USE. IF LEFT FOR SOME TIME, IT WILL START AGAIN FINE, THEN AFTER A FEW MINUTES MORE USE , IT WILL SWITCH OFF AGAIN.
check all filters, if they can be washed do so, if not clean or replace. next check for a clog in the machine and in the hoses. the machine as a thermal device that if it senses an overload or getting to hot, the machine will shut itself off for safety resons.
Jul 28, 2009 | Vacuums
Dies after a few minutes of vacuuming
The thermal cut-off in your machine is activating - this indicates that you have a blockage or a clog in the machine. The machine will turn itself off so that the motor doesn't overheat - the machine will cool off and you'll be able to turn it on after 30 mins to an hour.
Call the Dyson Helpline for a thorough blockage check - they know what they are doing.
Jun 15, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Bosch BSA2222UC canister vacuum shuts off after 5 minutes
You have a plugged vacuum indicator port. There will be a tiny hole somewhere near the hose inlet. Just clean it with a dry toothbrush. This will allow the vacuum pressure to equalize on either side of the shut off switch.
Jan 03, 2009 | Bosch BSA2222UC Compact Plus Bagged...
Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
102 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
