Question about Air Tools & Compressors
Where can I get a manual & parts for a Nikota 2 hp, No 30571 air compressor?
5 Suggested Answers
  • 4088 Answers
SOURCE: I have a Craftsman air compressor twin cylinder, 2
Go to: www.searsparts.com
The pressure control switch which the compressor usually pumps into and is mounted on the tank, contains a backflow check valve, the pressure regulator switch, and a compressor pressure release valve. It's probably available only as a complete unit. The pressure switch itself is usually a microswitch that can be obtained locally at a hardware or appliance parts house. Make sure that the pressure switch adjustment hasn't been set higher than the compressor can reach. If you remove the cover, you can watch for mechanical movement at the switch when it is supposed to shut off. Don't poke at anything in there with metal tools--220 volts will give you a lethal shock!
Posted on Oct 30, 2009
  • 54 Answers
SOURCE: A DIRECT DRIVE COMPRESSOR & THE PRESSURE SWITCH IS FAULTY
STOP! Your pressure switch is doing what it is supposed to, but the tank check valve is leaking. This valve is usually at the tank where the line from the compressor head enters the tank. The small tube line from the pressure switch probably also goes to this valve. You'll need to clean or replace it.
Posted on Nov 17, 2009
SOURCE: I have an 60 Gallon Air Compressor Husky Pro, no
Read the owners manual,look at the motor label
20Amp is usually for 2HP and may work for your 3.2
Look at full load rating on motor. You won't need a
breaker that high.
You will need 12 ga wire and 20 amp breaker min.
two wire 240 volt circuit.
It should be wired for the higher voltage,if not look at the
inside of the small motor cover and move the terminals
to the two pole rating. Expensive to run at 115volt
Posted on Nov 25, 2010
hunter19_46m
  • 7482 Answers
SOURCE: looking for a manual for Excalibur 7.2 CFM/2 HP
Hi loraogarek...
Go to the following webpage and download your owners manual.
Please take time to rate me
http://www.chpower.com/manualsearch/
Posted on Sep 18, 2011
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    What level does the coolant need to be in the sight glass?
    About 31,000 results (0.83 seconds) Search Results
      [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
      www.ingersollrandproducts.com/...
      Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
      [PDF]Owner's Manual - Air Compressors Direct
      www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
      installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
      [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
      diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
      EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
      Ingersoll Rand Air Compressors - About Air Compressors
      www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
    Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
    I have a nikota 3500 watt generator and I am not getting any power from the generator. Motor runs fine just no power. Is there anything I can check.
    All Power America APG3535CN, 2800 Running Watts/3500 ...
    www.amazon.com/...Power...Generator/.../B000U0OJ...
    Amazon.com, Inc.I then call All Power and am told to give them one more day to get this worked out ....There is no styrofoam enclosure or crate to protect it, the generator is simply ...
    NIKOTA 3500 WATT GENERATOR - YouTube
    ? 0:58
    https://www.youtube.com/watch?v=NEeu9Y-0_KM
    Aug 27, 2011 - Uploaded by mamasboypowersports
    NIKOTA 3500 WATT GENERATOR. ... Diagnosing A GeneratorThat Has No Power Output. - Duration: 3:03. TheDIYGuyDOTnet 117,263 views.
    I have a nikota 3500 watt generator and I am not getting any ...
    www.fixya.com/support/t26062098-nikota_3500_watt_generator_am_not
    2 hours ago - I have a nikota 3500 watt generator and I am not getting any power from the generator. Motor runs fine just no power. Is there anything I can ...
    Generator outputs low variable voltage, ideas for troubleshooting ...
    www.smokstak.com > ... > Generators & Motors General Discussion
    Jan 20, 2016 | Electrical Supplies
    Nikota 06041
    1/4" gas line can be bought at any Auto Parts place. Any generic shutoff can be bought there too.
    Dec 09, 2013 | Electrical Supplies
    I have an old IR 30 T that needs repair where do I find a manual for this
    You may find your parts manual for your compressor here http://www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
    Just scroll down the page, the manual for an IR 30 is there, also on that website, you may find the problem to your compressor
    Sep 29, 2012 | Ingersoll Rand - Rand Type - 30...
    How can i get owners manual
    Go to the Campbell Hausfeld home page at http://www.chpower.com/. Under Service & Support select Manuals/Parts Lists. Search on your model number and you'll get the manual and parts breakdown.
    Mar 08, 2012 | Campbell Hausfeld 2 Gallon Air Compressor
    Restriction
    The cap tube is clogged and the unit is overcharged. Get used to this on beverage air units.
    Nov 18, 2008 | Beverage-Air Beverage Air 2- Tap Unit...
    Air Tools & Compressors Logo
    146 people viewed this question
    Top Air Tools & Compressors Experts
    John Trevino
    Joe Garcia
    Joe Garcia
    Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
