Question about Drills
Hello, I have just bought a Drill Press (Older model) it is from the Orbit Machine Company. It is Model OR - 1412. I would really like to know where I can find an owners manual. This seems like an awesome machine... very true and runs well. My second question would be about a switch. There is a switch that says "M" beside it. I hit this switch and the Drill turns on. DIrectly below this switch is another swith labeled "L". When I hit this switch nothting happens. All wires seem to be hooked up and clean. Just wondering what it might be for? Thanks to anyone who responds! Herb Allen
The "L" switch is for a light, a bulb screws in/up right behind the drill chuck!
Posted on Jul 17, 2015
rowdy45176
  • 2176 Answers
SOURCE: how to remove chuck from drill press
I just looked at a breakdown for this tool and it is not that clear. But to get an owners manual you can go to Searspartsdirect.com and type in your model number and look at the same schematici I did and also order a manual for about 7.50. Usually though on a drill press like that it would be a morse taper. Do you see a slot cut thru the spindle on both sides, if so there should be a tapered key that came with the unit. In that case what you would need to do it put the key in the slot and tap it with a hammer to remove the adaptor and chuck. Let me know if I can help further
Posted on Jan 03, 2009
  • 10865 Answers
SOURCE: Replace drill chuck on 23 year old Craftsman 8" drill press
Yes it does have a Morse taper and you can remove it by gently hitting it with a rubber or nylon mallet.
Posted on Feb 08, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Delta drill press model DP350 went out while using it
Check for power at the on switch. The switch on this machine should be electrical so yes it could go out. If it is not the electrical type then I would check to make sure that the internal switch did not brake or go bad.
Posted on Feb 17, 2009
rowdy45176
  • 2176 Answers
SOURCE: Where do I get parts for a clarke drill press model bt1029?
the part number I found is BT1029-0038 for the quill spring and you can contact them at 1-800-227-9603 and see about ordering the part. If I have helped you would you please rate this response accordingly and thank you.
Posted on Oct 13, 2009
cojon
  • 7 Answers
SOURCE: need manual for craftsman drill press model 113.213853
To correct that 2 degree angle, there is often an allen screw at the bottom of the table swivel. Look where the nut to loosen the table is. Under it is an allen head screw. loosen the table swivel a bit and turn that in an eight of a turn at a time, re tighten then remeasure.
Posted on Jan 04, 2010
My husband has an old Orbit Machine Tools drill press, model OR1412. Any idea where he can get an owners manual?
Looked it up on Internet possiblely found need serial number go to www. Milwakee.com
Dec 05, 2014 | Drills
How do you remove the drill chuck on a vintage delta 14 inch drill press model dp-220
Thread Changing chuck on older Delta drill press This site speaks on the subject of changing chucks. It may be helpful. Also if you search;' how to remove a jacobs chuck from a delta drill press' , you should get several hits I hope this info is helpful....
Oct 17, 2013 | Delta Woodworking Drills
I'm trying to locate the manual for a Powerline Drill Press Model # DPS565P. Any help would be appreciated
hello, maybe you can ask the manual to where you bought the Powerline Drill Press Model # DPS565P. or you can ask a technician. .
Apr 27, 2011 | Garden
I need to get a downloadable copy of an owners manual for the Dayton 10" drill press, model # 4CY85
hi joel i can get you a users manual for your drill press do you have a fax machine ? or i could mail it to you let me know.
Mar 17, 2011 | Dayton Audio Dayton 4CY85 Bench Drill...
I don't really have a problem, I bought a used Clarke Metalworker model BT1001A and I need a manual for it. Can I get one from you? If so, how much? Demi skypilot2@sisterlakescable.com
Most drill presses are very similar and simple. Here is the parts list for yours and here is a manual from Pioneer that shows several models. You should be able to follow the instructions for the Pioneer model that is similar to yours. Compare the parts lists if you encounter differences in the details.
Dec 08, 2009 | Clarke Power Products Clarke 16-Speed...
Troy-bilt Model 47279
I really hate to be the "bearer of bad tidings" but Troy Bilt, as a company, in no longer in business, MTD bought out the name and design rights for a lot of their tools but they are not manufacturing or stocking any parts for the older GardenWay/ Troy-Bilt machinees. My best suggestion would be tostart looking for a good used one or one with a blown engine, broken frame or whatever, buy it and canibalize it for spare parts
Sep 16, 2009 | Troy-Bilt Chipper Shredder
Drills Logo
499 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
