Question about Garden
The blade will not move - Garden
  • 520 Answers
If this is a chainsaw, then may be the safety gaurd needs to be released. it should be right near the top handle, move it one way or another. You could also have it plugged up. take the side off like you are putting on a new chain. look for obsicles stopping movement
Posted on Oct 04, 2010
Why is blade not moving?
Either the gears are trashed, OR SOME machines have a "CENTRIFUGAL CLUTCH" [a safety feature] between the engine and the blades. This is to ensure that the blades don't move when idling, and move when at full throttle.
IF your machine has this feature, then it's possible that the clutch has worn out and is slipping so badly that the blade won't move.
Jun 10, 2014 | Black & Decker Garden
Wahl clippers
Check to see if the blade is moving when turned on. If the blade isn't moving the clipper blade may need to be thoroughly cleaned. If the blade is clean and well lubricated but still not moving you may have blown the motor.
However, if the blade is moving freely when turned on, and the hair/fur is just not being cut (or is cutting raggedly or pulling at the hair/fur) you will need to get the blade sharpened.
May 02, 2013 | Wahl U-Clip Deluxe Home Grooming Pet...
My brother overlocker blades dont cut anymore and thet dont move either, please help!!!
if the blades don't cut then they need to be replaced,, and for the
blades not moving,, the machine need to be checked..
Apr 19, 2013 | Sewing Machines
Hit fence with blade and now it wont move
Without direct exposure to this model, check the parts catalog, there is more than likely some type of coupler between the engine and blade assembly. Usually they are added for exactly this situation. Worse case senerio, the gearbox for the blades is "toast".
Oct 05, 2012 | Poulan Ght225 25cc Gas Hedge Trimmer
Motor buzzes, fan does not move, blade does not move, blade is clear of obstruction
Removing blade will not do it - there has to be an obstruction in the drive mechanism that prevents it from turning. Leave off till fixed lest you risk burning out the motor completely. Turn on AFTER you can turn the blade freely.
Sep 03, 2017 | Remington 3-Amp 17" Extended Reach...
We have an Oster 78950-100-700 model and I dont' think it worked out of the package. It seems that the head does not move. It is like the bottom blade is putting to much pressure on the top blade and so...
The two screws of the blade guide are tightened completely. Adjust the tension between the blade and the blade guide with the large plastic screw on the side of the trimmer (this allows the blade to move rapidly from side to side). I plug it in at this time and when the cutting blade begins to move the clipper makes much louder noise. This is normal but it sounds like it is broken, it isn't. Adjust the cutter slightly past movement. You don't want it to bounce on the guide
Feb 27, 2011 | Oster 78950-100
Circular saw blade rubs on the guard
remove the blade and check for the inner flange that should be behind blade. also there might be a ring underneath the inndr flange. or check to make sure the flange is installed correctly.
Apr 05, 2010 | Ryobi Saws
Motor runs, but blades dont move
with engine off, take a screw driver and manually move the blades to make sure that they are not jammed. Then spray the blades down with wd-40 oil and they should move freely again.
Jul 28, 2009 | Garden
My B & D electric hedge trimmer blades are frozen
spray liberally with wd40, let side and hour spray rag with wd40 and clean blades and look for any bent teeth in blade that maybe binding them as u clean use pliers and screwdriver to move if any found, it is likely that wither sap dried or rust formed and is creating too much friction for blades to move wd40 will help free up blades
Jul 09, 2009 | Black & Decker Black Decker 16" Hedge...
After reassembly blade will not cut wood, does not maintain suffient tension despite being correctly inserted
It sounds like the blade is not going through the guides properly if the blade is being pushed away from the wood.
Your blade is facing and moving the right direction, I am assuming.
Apr 17, 2009 | Saws
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
