Question about IBM ThinkPad T42 Notebook
My TP showing round circle with z symbol on and screen is not appearing
Unable to unlock the Nook. Screen lights up but the small green circle which I allign with the lock symbol does not appear. Screen shows correct time and date as well as my wallpaper photo.
Sound like voice activation try and hold the volume buttons till it say talkback suspended press ok a few times quickly and then it will say talkback suspended
Aug 07, 2017 | Apple iPad Tablets & eReaders
Tip
How to create motion across the screen?
Step 1
Create a small circle to the left in the Stage area. Do this by selecting the circle tool from the left toolbar. Draw the circle in the Stage area.
Step 2
Select the Arrow tool from the left toolbar. Double-click on the circle to select it.
Step 3
Now we have to convert the circle to a symbol. When the circle is converted to a symbol we can create instances of the circle. From the top menu choose Modify > Convert to Symbol. Name the symbol "Ball", and select OK.
Step 4
Go to Frame 10 in the Timeline. Do this by clicking the gray field below 10. Then right click in this field. Choose Insert Keyframe. Keyframes appear as circles in a frame. This operation duplicates the image.
Note: A keyframe specifies changes in an animation. You create keyframes at important points in the Timeline and let Flash create the frames in between.
Step 5
Select the circle and move it to the right a couple of inches.
Step 6
Click on the Timeline any place between Frame 1 and Frame 10. Then right click and choose Create Motion Tween.
Step 7
Choose Control > Test Movie from the top menu to test your Flash movie.
on Aug 11, 2008 | Adobe Flash® CS3 Professional Full Version...
What is the meaning of the various symbols on the line with blutooth and charge percent etc. In particular, the symbol with a lock with a circle around it?
The lock with a circle around it means you have locked the screen rotation. This means when you rotate the device, the screen will not rotate.
If you want to turn off the screen lock, just swipe up on your iPhone screen and turn it off in the panel that appears.
More information is available on the Apple website: https://support.apple.com/en-us/ts3805
Hope that helps!
Mar 12, 2015 | Apple iPhone 5
Unlock
The Lock symbol needs to moved to the right to the unlock symbol by your finger.
This will then load the desktop and activate the touch screen.
Support Troubleshooting Guide
Apr 18, 2014 | Kocaso M730W 1.2GHz 4GB 7 Capacitive...
Factory reset ftm symbol shows instead of hp symbol
Plug the supplied charger in to the TP and into the wall. Then hold the power button and the button at the bottom of the screen simultaneously. After about 10 - 15 seconds the TP reboots.
Apr 09, 2014 | HP Tablets & eReaders
The symbol is a round orange circle with ! sign inside and lines
Brake pads require checking
This warns you early so you don,t ruin discs
Dec 24, 2009 | 2007 Mercedes-Benz SLK280 Roadster...
Won't Take Pictures
My nikon coolpix 4500 has the flashing red clock as well with the hands of the clock pointed to 9 oclock and a white dot on the oppostie side of the 9
Dec 28, 2007 | Cameras
Loading circle constantly onscreen
Try formatting, synch your library using a synch software like media player, realplayer, media monkey etc. Do not remove the USB if it is 'Updating'.
Apr 27, 2007 | Toshiba gigabeat S MP3 Player
Won't Take Pictures
contact nikon they know about the problem and will fix it for free
Sep 02, 2006 | Nikon Coolpix 5700 Digital Camera
IBM ThinkPad T42 Notebook Logo
320 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
