Question about Samsung LN-R328W 32 in. HD-Ready LCD Television
How do I remove cover from samsung 32 lcd tv -- is there a hidden screw somewhere? are there any instructions anywhere?
  • ash2566 Oct 04, 2010
    the model number is LN32A3301DXZA
    President:
  • 2,777 Answers
Can you give me the actual model number to your Samsung, it's on the back label... It should definitely come apart.
Thanks
Tim
Posted on Oct 04, 2010
  • Tim Grayson
    Tim Grayson Oct 04, 2010
    You can't find any screws on the back of this unit? Or you have removed many but just can't get it out still? I bet this video will be of the most help...
    Part 1 is really all you should need to get it apart:
Speaker went out. What should I do?
you can purchase a replacement speaker from somewhere like tigerdirect.com, then its just a matter of taking off the back cover of the television set and replacing the speaker...
it should only be four small screws and the wiring plug to get the speaker out, then reverse what you did to remove, to replace.
Apr 14, 2011 | Sharp LC-32SB24U 32 in. LCD TV
How do you take the stand off a LN32B530 in order to wall mount it?
The manual for this model is located at
http://downloadcenter.samsung.com/content/UM/200903/20090331173532953/BN68-01883M-00L02-0219.pdf
From what the instructions say, there are 4 screws on the back of the tv, at the bottom.. These go through the tv and into the base. Remove them and it should come off.
Mar 06, 2011 | Samsung LN32B530 32 in. LCD HDTV
2008 Samsung 32" Flatscreen 720p Channels are
The cc has been enabled on your cable box. Usually there is a hidden menu accessed by turning off the cable box. Yes I did say turning off the cable box first. Then immediately pressing the menu button on the front of the cable box. The hidden menu should pop up and one of the menu options will be closed captioning,. Disable it.
Nov 09, 2010 | Samsung LN32A540 32 in. LCD HDTV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Removing tv stand
Remove the screw and pull the TV upwards.
Have someone step on the stand
Dec 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
How disassemble?
Open battery covering and (A/V/USB) covering - find a hidden screws there.
Aug 19, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
How to get pedestal off a toshiba 32 HL 67
Take out 5 HEX head screws and one black screw from jack pack cover. the pedestal will slide out from bottom. You do not need to remove jack pack cover as it is part of entire back panel.
Mar 05, 2008 | Toshiba 32HL67 32 in. LCD Television
LCD TV
There is more than two screws holding the back cover on. I think it is more like 4 to 6. After you have removed all the screws you will nee a flat screw driver to help pry the two halves apart. Be careful the front of the cover has little snaps that help hold the two together.
Jan 05, 2008 | Samsung LN-T1953H 19 in. LCD HDTV
Samsung LN-R328W 32 in. HD-Ready LCD Television Logo
124 people viewed this question
Henry  Thomas
Henry Thomas
