Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
No video I recently put in an asus m2n mobo and i can't get any video. I got a new video card and put in compatible memory which is also new. Specs 2x Corsair Dual Channel TWINX 1024MB PC6400 DDR2 Thermaltake Max orb Thermaltake pci fan Amd Athlon 64 X2 3800+ Evga 8400 GS Linksys wireless nic ide drive sata drive
  • tmomonet May 27, 2008
    also no post
  • tmomonet May 28, 2008
    itll be tricky to get drivers w/o video. plus the card should be ok and so should the monitor. plus i tried it w/ another monitor and no sale.
  • 45 Answers
Could be that the drivers are not correct for the monitor/videocard that you have set up. have you tried downloading some newer ones from your monitors manufacturer?
Posted on May 27, 2008
  • K L'Heureux Jun 03, 2008
    i know geting the drivers without video is problematic. but if a second monitor doesn't work then i'd say you have a faulty video card. have you tried putting it into a working system and seeing if it works there?
I flashed the bios on my Asus motherboard M2N-E, and then replaced the processor with a quad. Cleared the cmos and now the computer won't post? What do I need to do to get it up and running again?
Try to put back the old procie, if it runs again that means the new procie is not compatible with board.
Read the manual for the compatibilty issue for your MoBo.
Tell me if it works.
Nov 17, 2011 | ASUS M2N-E SLi Motherboard
I have am2n-e sli mobo, amd 5200+ 64bit dualcore cpu, 4x1gb ddr2 ram sticks, gf 430gs pcie video, 500watt psu, 2x ide and 1 sata hdds, and a ide dvd burner post check beeps one long then two short, with...
The one long-two short beep code is for bad memory, not for a failed video card.
Shut down your computer, remove one stick of ram, reboot the computer, and repeat for each stick of ram, until you find the bad stick.
Feb 28, 2011 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus M2N-MX se plus board.... compatible with GF
maybe it is an AGP slot, there is also a pci-e slot.
Jul 13, 2009 | ASUS M2N-MX SE Motherboard
Motherboard will not display video!
remove everything except for video card and memory cd hard drive etc give it a try
if it shows boot screen you have problems in something you disconnected retry one at a time
if not try different video card
Aug 16, 2008 | ASUS M2N-MX Motherboard
NO video @ bootup
Are you sure that the memory you have installed is compatible with your motherboard.
It is weired but some memory do not work with certain motherboards, irespective of speed or voltage rating.
Aug 05, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus motherboard M2N-E will not power up
It could be a memory card too. I would start by pulling the memory cards and see what happens.
Is there a connection on the motherboard for your hard drive?
Jun 12, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Burned motherboard....
If the chip on the bord burnt after seating the video card, I'd be inclined to throw both the motherboard (as it'll not be safe or stable enough to use now) and the video card (as it likely shorted the board) away ...
May 25, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Video card
This may sound weird, but remove ram to make it 2 gigs and try it again, some mobo's have issues with 4 gigs. 3 gigs usually works too.
Apr 03, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus M2N-MX Motherboard 4gb Ram wont work
I had the same problem and ASUS tech support was of no help. I did however find the culpret in the BIOS setup. Go to Advanced, Chipset, NorthBridge Chipset, and Memory Configuration. Set the Bank Interleaving to Disabled and save the settings. Check these settings also while you are there:
Channel Interleaving = Auto
Enable clock to all DIMMS = Disabled
Memory Tristate = Disabled
Memory Hole = Enabled
Unganged Mode = Enabled
Power Down Enable = Enabled
Power Down Mode = Channel
By Wayne F
Dec 19, 2007 | ASUS M2N-MX Motherboard
Serious problems with an Asus M2N E SLI motherboard.
try the board with out memory and hard drive.
Do fans run?
Anything?
Nov 21, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
146 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
