Question about Price Pfister Plumbing
I have a two handled price pfister kitchen faucet and replaced the cartridges and now have low water pressure what did i do wrong?
Probably the diverter, order from mfg & replace or you can disassemble diverter and replace internal white part and O ring which is what I did and worked great
Posted on Nov 20, 2010
My kitchen faucet handle makes a screaming sound and will not turn the cold off
Either you didn't seat the o rings properly or they are the wrong size or the cartridge needs replacing
Jul 18, 2014 | Price Pfister Marielle Kitchen Faucet with...
I need a replacement cartridge # 17196-0100k for a single handle price pfiser shower valve. where can i order one?
I have a single handle price pfister shower valve Model 17196-0100k .No cold water.It's coming hot on both sides.
Mar 28, 2011 | Price Pfister R89-7PC0 Chrome Portland...
We have a new Price Pfister 49 Series bathroom faucet set with two handles. Even with the hot water tap open full the water just dribbles out
If you have full pressure on the cold water side and low pressure on the hot side then you well need to remove and clean or replace the cartridge for the hot side. If you have low water pressure on both sides try removing the aerator and cleaning it.
If you need to replace the cartridge on the hot side do both sides while you at it.
Whenever you work on any faucet before you turn the water on remove the aerator and run the water for a few seconds then replace the aerator.
Mar 07, 2011 | Price Pfister Two Handle Lavatory Faucet -...
I have a Price Pfister 34 Series Genesis Single-Control Faucet, 3-hole with side sprayer, in my kitchen and it has developed a leak. Specifically, when I lift the lever it leaks from the handle, and when I...
The cartrididge seals have gone bad for what ever reason and the repair is simple enought but I woul take the replacement unless they want to pay for the plumber to come and fix it.
Feb 18, 2011 | Price Pfister 34-3LC Genesis Kitchen...
Dripping faucet price pfister kitchen
Very nice kitchen faucet. I like Price Pfister's products. To repair it you will need a phillips screwdriver to remove the handles and crescent wrench to remove the cartridges. If it is dripping then one of the faucet cartridges need to be replaced. Its best to replace both cartridges as inevitably the other one will start to leak after you've replaced the troublesome one. Your local hardware store or plumbing supply store should have a replacement cartridge for this model. Remove one of the cartridges and take it with you to ensure you get the correct part. There is an exploded diagram of your faucet on the Price Pfister site at that shows the part number for the cartridge. Good luck and let me know how it turns out.http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/savannah/savf8h6-85/ex-036-01.pdf
Jul 25, 2010 | Price Pfister Savannah Two-Handle Kitchen...
Water runs slow
Three possible reasons for low pressure. 1. faucet cartridge has debris in valve body. 2. aerator has debris ,just unscrew and clean out. 3. Water valves under sink are not opened up. hope this helps
Jul 30, 2009 | Price Pfister Marielle Kitchen Faucet with...
The handle won't stay up at low water pressure.
need to tighten cartridge house or too much lube on cartridge. dont tighten to much 1/8 inch at a time and check.
Jun 14, 2009 | Price Pfister 34-3LC Genesis Kitchen...
We cleaned our price pfister faucet because we had low cold water pressure - when we hooked it back up and put the handle back on the water will not turn off.
You more then likely replaced the diverter washer backwards. There is a washer/gasket that has multiple holes (2 or 3) and it is probably just rotated 180 clockwise (or counter).
There are very few moving parts in a faucet so this should fix it.
Apr 13, 2009 | Price Pfister 34-3LC Genesis Kitchen...
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
212 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
