Question about Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer
My canon mx340 all in one is saying..printer not responding.when i try to print..its wireless too!
ikechinedu
  • 184 Answers
SOURCE: Canon PIXMA MP190 'not responding'
There are possible causes of this not responding status message you get. you will try out these option i have listed here and see which one resolves the problem. after each one, try to print from a file and from the web.
1. Configure driver to correct printer port
On the 'Ports' tab of 'Printer Properties' window, select the correct port for the printer driver.
From the Windows desktop, open the printer's properties window.
Click the Ports tab.
Below 'Print to the following port(s)' section, select the port to which your printer is connected.
Click 'Apply' to accept the changes.
Click General tab and then click 'Print Test Page' to confirm the changes corrected the issue.
2. Checking USB Connections
You should disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists.
Disconnect one end of the cable and then reseat it ensuring the cable is firmly seated into the USB port. If the USB cable is plugged into a hub instead of directly into the computer, try connecting the USB cable directly into the computer.
Repeat step one to reseat the cable on the other end.
3. If there is still no communication, then it may be necessary to try a different USB cable or a different port on the computer.
when you are through, restart the system.
4. Uninstall and Reinstall the Driver
If the MP Navigator or the MP drivers are no longer required, or if they are not installed correctly, uninstall them.
Caution: Uninstalling means deleting software, such as MP drivers, from the computer. Once the software has been deleted the unit cannot be used through the computer until the software has been reinstalled.
Note: Login as a user with Administrator privileges to uninstall . Turn off any programs running in the background, such as antivirus programs and firewalls before begining.
Select 'Program' (for Windows 2000), or 'All Programs' (for Windows XP / Vista) from the Start menu.
Select the name of the printer model to remove and select 'Uninstall.'
When the MP Drivers Uninstaller window is displayed, click 'Perform.'
When the confirmation window is displayed, click 'Yes.'
When the Uninstallation Complete window is displayed, click 'Complete.'
5. Reinstall the Drivers
Note:
The MP drivers can be installed using Easy Install or Custom Install.
Easy Install automatically installs the software which is in the CD-ROM.
This method is recommended if you are a first-time user.
Custom Install allows you to select the software programs from MP Drivers, Application Software, and On-screen Manual.
Login as a user with Administrator privileges to install on WindowsXP/Vista/2000.
Close any antivirus software that may be running prior to installing the drivers.
Turn off the printer and disconnect the cable connecting the computer and the printer.
Insert CD-ROM in the computer. (The CD-ROM will start automatically and the following window will be displayed on the screen.)
If the setup program does not start automatically, click 'Start' and go to 'My Computer', then double-click the CD-ROM icon.
If you use Windows Vista, select 'Computer' from the Start menu, then double-click the icon of the CD-ROM.
At the main installation window, click 'Easy Install' or 'Custom Install'.
When selecting Easy Install:
(A) Click 'Easy Install'.
(B) Click 'Install' in the following window.
* Display varies according to the printer model.
When selecting Custom Install:
(A) Click 'Custom Install'.
(B) When the following window is displayed, click 'MP Drivers' and the application software to be installed, and then click 'Next'.
When the License Agreement window is displayed, read the content carefully and click 'Yes'.
The installation will start.
Messages may be displayed during the installation of the application software.
Follow the instructions on the window and continue the installation.
When the Printer Connection window appears, connect the printer to the computer and power on the printer.
Note: If the installation cannot proceed even after 2 minutes, stop the installation by following the procedures below and start from the beginning again.
1) Click 'Cancel' at the Printer Connection window then click 'Start Over' at the Installation Failure window.
2) At the window to install the driver / applications appears, click 'Back' then click 'Exit'.
3) Restart the computer.
4) Install the printer driver again.
For Windows XP, at the Welcome to the Found New Hardware Wizard dialog box, confirm Install the software automatically (Recommended) is selected, then click 'Next'.
Note: The Welcome to the Found New Hardware Wizard dialog box may be behind the Printer Connection window.
In this case, click 'Found New Hardware Wizard' button on the task bar to display the window.
After the files are copied automatically and the dialog box Completing Found New Hardware Wizard window appears, click 'Finish'.
If the Welcome to the Found New Hardware Wizard dialog box appears again, click 'Finish' again.
At the Print Head Alignment window, click 'Execute'.
Note:
* The Execute button may not appear for all models. In that case, skip to step 13.
* The Print Head Alignment can also be done after the installation of the printer driver.
When the Start Print Head Alignment window appears, load one sheet of A4 or letter size plain paper in the sheet feeder and click 'Print Head Alignment'.
At the Do not start another operation until current one has finished dialog box, click 'OK'.
When the pattern is printed, click 'Next' at the Print Head Alignment dialog box.
At the Installation Results dialog box, check the content then click 'Next'.
The installation of the MP drivers and application has completed. Proceed to the Canon user registration.
If you want to register now, click 'Register'. If not, click 'Next'.
Registration can be done after the MP drivers installation.
Then, Inkjet Extended Survey Program will be launched. If you agree, click 'Agree'. If you do not agree, click 'Do not agree'.
At the Installation completed successfully dialog box, click 'Exit'.
Note: When the Restart button appears, confirm that Restart the system now (recommended) is checked then click 'Restart'.
Posted on May 22, 2009
crapiemael
  • 241 Answers
SOURCE: what does it mean when my printer canon MX340 says
It's turned off to not print. Go to the printer in your devices, and right click and select "online".
Posted on May 11, 2010
  • 707 Answers
SOURCE: How to change ink cartridges
here ya go.
http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx340
Hope it helps
If this helps you resolve your problem, please
consider giving me a good rating and a quick
"thanks" or "good job".It will help me as well.
Thank you.
Posted on Oct 28, 2010
  • 128 Answers
SOURCE: Canon pixma mx340 4-in-1 wireless
error 6000 is a paper jam, which means there is something in the flag that senses whether or not there is paper in the path. Look very carefully in the area just before the paper comes out before the printing area. You will likely find a small piece of paper stuck, or a small object. Often a small inspection mirror helps.
Posted on Nov 01, 2010
  • 1335 Answers
SOURCE: I have a canon pima mx340 printer/fax machine. How
Printing a Memory List or Specified Document in Memory
1. Load paper.
2. Press the FAX button, then press the Menu button.
The Fax settings screen is displayed.
3. Use the button to select Memory reference, then press the OK button.
4. Print a specified document or memory list.
· To print a memory list:
Use the button to select Print memory list, then press the OK button.
The memory list is printed.
· To print a specified document:
1. Use the button to select Print specified doc., then press the OK button.
2. Use the Numeric buttons, or the button to select the transaction number (TX/RX no.) of the document you want to print, then press the OK button.
3. Use the button to select Yes, then press the OK button.
If you select Yes, only the first page of the document will be printed. If you select No, all the pages of the document stored in memory will be printed.
To print other documents, repeat the procedure from steps 2 to 3.
Posted on Nov 08, 2010
Need to clear In Use/Memory light on Canon MX340 printer
Step 1 Press the "Menu" button on the MX340 until "Device Settings" appears on the LCD display.
2.
Press the left or right arrow keys to select "Reset Settings," and then press "OK" to load the Reset Settings menu.
3.
Press the left or right arrow keys to select "All data," and then press "OK" to reset data on the MX340 to factory default settings.
Apr 14, 2015 | Canon PIXMA MX340 Wireless Office...
My printer is not responding while printing
If its printing, that's your response. What specific response are you looking for?
Aug 18, 2013 | Canon PIXMA MX340 Wireless Office...
How do i print from a canon mx340
what menu settings do I need for canon Pixma 340 to print
Apr 02, 2013 | Canon PIXMA MX340 Wireless Office...
To whom may it concern, I current have Canon MX340 and I tried to print out some papers but it showed "Printer not responding" What should I do now? Thanks, George
George,
It sounds as though either the printer is not talking to the pc or the pc is not talking to the printer.
Unfortunately you do not say how you communicate with the pc. Is it wireless or via usb?
I would probably reinstall using the cd if its a wireless setup. Can you print via usb? If you can then do the above.
Repost if you are still stuck.
Jun 20, 2011 | Canon PIXMA MX340 Wireless Office...
My canon mx340 will not print from my laptop wireless....keeps saying offline
Is the Printer switched on? Do you have enough rights to use the printer wirelessly? Have you printed documents over your wireless connection previously?
Mar 15, 2011 | Canon PIXMA MX340 Wireless Office...
Canon MX340 I just replaced the ink (black and color). Black now prints in grey. What to do?
if you put a refill cartridge the printer are printing in grey.Try to put original cartridge canon.
Mar 09, 2011 | Canon PIXMA MX340 Wireless Office...
I can't print anything on printer, and when I try, it says the printer is not responding. In Printers and Faxes, it says it is ready.
helaineliew,
Sure sounds like you have another printer as the default. Click on start. Then click on control panel. Click on printers and other stuff. See which printer is set as the default. If the Canon Pixma mx340 isn't change it. This should solve your problem.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 13, 2011 | Canon PIXMA MX340 Wireless Office...
My Canon MX340 is all set up wirelessly and has the blue light on. But when I try to print something from Word is shows that the printer is not responding. I know it prints because I used it to copy...
You MUST put in the password of the router in or it will never connect. Pressing a number key several times quickly should change the number to letters.
May 16, 2017 | Canon PIXMA MX340 Wireless Office...
Hi, my canon mx340 keeps pausing during printing. any idea why?
The pause state which occurs intermediate to printing is mainly due to the cachins process/ Spooling/
To avoid this > go to Device properties of Printer. >Check for and option relating to print option >It would say "print directly to printer" or "Print only after complete buferring or sppooling" >Choose the option relating to "Print immediately" or "Dont wait for spool"
everything will be fine.
if you still encounter this problem then it is mainly due to heavy traffic on the shared network link. try to drop a leased link for thhe printer. The MFD(multi functionDevices) usualy require aheavy bandwidth for their operation.
:)_
Nov 30, 2010 | Canon PIXMA MX340 Wireless Office...
Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer Logo
3,412 people viewed this question
old marine
old marine
